Introduction: DIY Popsicle Stick BirdHouse
I always think of building a Good House for Birds.But wasn't able to do so due to time constrains. So,Now I finally decided to make a small House for them. I gathered all the parts and started building one using Ice-cream sticks. Hope you will like my Instructable
- Ice-cream Sticks
- Cello - Tape
- Hot-Glue Gun
- Cutter
- Scissor
- X - Acto Knife
- Sunboard 5mm
Step 1: Support Structure and Roof for BirdHouse
Initially I made the Base of the BirdHouse for that I used 9 sticks and lined them together and taped them all.
Then I used 2 sticks lined them together at 90degree and glued it, make 5 pairs. 4pair would be used as pillars and the 5th pair would be used to join the roof.
To make roof I took 10 sticks and lined them together and taped them as shown the picture.
Also I created some room so that I can place food for the Birds. Take 3 sticks cut them in Half and glue at the Base of the BirdHouse
Step 2: Side Walls of BirdHouse
Now Take a Sheet of SunBoard. Make 3 Slices of Dimension 110x80mm to place on the Sidewalls of the BirdHouse. Glue those pieces with Hot Your BirdHouse is almost ready.
Step 3: Final Stage
In this Final Stage, Glue the roof to the structure of the BirdHouse. I was having some place plastic sheet(optional) lying around so I used it as a placeholder for Bird Food. Now attach any string to the BirdHouse which goes under the roof.
Now place some shredded leaves inside your BirdHouse. To give it a nice touch I made a small Bird with eggs out of clay as it is windy and raining outside I would be using by BirdHouse indoor for decoration only.
Thank You!!
