Introduction: DIY Portable Fan
as summer had arrived we all are suffering from very hot and dry wether
and when we are playing with friends in the park its really a pain because of the hot wether so this is it
i am going to show you how to make a portable fan which will make you cool
Step 1: Tools Needed
motor
power supply(example 9v battery)
switch
battery connector
some basic tools
this is all you need to make a portable fan
it costs only under 2$
Step 2: Heat Up the Soldering Iron
just connect the motor with the switch to the connector and hot glue it together
note before gluing take your propeller and test that whats direction its throwing the air if it is on the wrong side then just side then just switch the wires of the motor with each other
Step 3: Its Done
you are already done thats how easy and fun it is to make a portable fan
it consumes around 50 to 100 mah
so it is going to give you a better battery life
check out our youtube channel and see it in action
https://www.youtube.com/channel/UCgdTN9c6dVWrnffGs...
our facebbok page
