DIY Portable Power Bank From an Old MacBook Battery
Intro: DIY Portable Power Bank From an Old MacBook Battery
Parts needed
1x MacBook battery cells, it's also possible to use another type of battery.
1x DC-DC converter USB module (with charging) - from eBay ~5-7$.
Electrical wires for making connections
Material list:
- Solder wire (Tin)
- Flux
Tools needed:
- Soldering Iron
- Pliers
- Wire stripper
- Multi-meter
STEP 1: Step 1
Check the Lithium cells. It's preferable to choose only the "live" cells that have at least 3+ volts stored. Avoid using cells that are over discharged or that have 0 volts as they may burst when are being recharged.
STEP 2: Step 2: Solder the Cells
Solder all tested cells in parallel. Take care not to overheat the batteries as they are sensible to heat excess.
STEP 3: Step 3 - DC-DC Module PCB Install
Connect the battery terminals to the DC-DC converter module, following it's provided indications on activating it. After it starts connect USB power to charge the cells.
STEP 4: Step 4: Full Video Guide
All the procedure in a video.
4 Comments
davintosh 6 years ago
Great project idea; thanks! I just acquired an older MacBook with a battery that won't charge, but I'd like to separate the good cells from the bad; any thoughts on how to extract them from the frame without damaging them?
livanov 8 years ago
Awesome project, How do I find such a dc-dc module i've looked all over for it
TechTronic9000 8 years ago
Just search on eBay for USB power bank module, or power bank PCB module, there will be lots of results, prices vary from 2 to 7 $ on averege, dependig on current output and functions (LCD), flashlight function, etc.
DIY Hacks and How Tos 8 years ago
Great way to reuse parts. Just be careful for those batteries. They can have problems if you don't treat them just right.
