Introduction: DIY Portable Whiteboard
A complete guide to making a portable whiteboard that you can take with you anywhere. It looks great even when the whiteboard is not being used. You can also order one at www.sketchcase.com
Step 1: Materials and Measurements
I'm using a 15-inch MacBook case ($18) and a 45cm x 200cm Whiteboard Sticker ($13) from Amazon. The measurements of the Macbook case is 36.1cm x 25.1cm.
Step 2: Mark the Cutting Area
I decided to cut the whiteboard into 35cm x 24cm to make a black border around the whiteboard.
Step 3: Cut the Whiteboard Sticker
Paper trimmers are available for free in major print shops. I'm using one from Staples.
Step 4: Attention to Detail
Make sure to trim the edges to your exact measurements. As you can see in the picture, the factory cut is off by around 2mm.
Step 5: Round Corners
The whiteboard sticker is now ready to be applied but first, let's make the corners round to match the Macbook case.
Step 6: Trace the Corners
Trace the corners with a pencil using the MacBook case.
Step 7: Cut the Corners
Carefully cut corners along the traced lines using a pair of scissors.
Step 8: Get Ready to Apply the Whiteboard Sticker
Get a plastic card and a dust cloth to remove the air bubbles without damaging the whiteboard.
Step 9: Apply the Whiteboard Sticker
Align and apply the whiteboard sticker starting with one edge. The sticker is not permanent so don't worry too much about getting it perfect.
Step 10: Remove the Air Bubbles
Wrap the dust cloth around the plastic card and remove all of the air bubbles. If the whiteboard is not aligned correctly, careful remove and reapply.
Step 11: Finished Product With Absolutely No Air Bubbles
This is actually my second time making this. I was so happy with the result the first time that I decided to do a DIY guide and share it with everyone.
I received so much positive feedback from writing this DIY guide that I decided to invest some time to make it available to everyone! You can pre-order one (or three... ?) by going to www.sketchcase.com
