Introduction: DIY Power Bank ?
Before Starting if you bored of reading you can check out my YouTube Channel for Full video tutorial.
So lets get started
Step 1: Gathering Parts
List of Parts:-
18650 Li-ion cells
TP-4056
Step up module
Wires
Soldering iron
Solder wire
Case
and a bit of Patient.
Also Huge Thanks to www.JLCPCB.com for Sponsoring this project, You can order 2 layer PCB (10cm*10cm) only for $2 from their website. Built time for 2 layers PCB is only 24Hr with any color solder mask. Check them out and once again Thanks www.JLCPCB.com for Sponsoring this project.
Step 2: Building the Battry Pack
1) Before building the battery pack check that voltage of both the battery it shall be same.
2) I used some hot glue the keep both batteries together you can even use tape or a heat shrinking tube.
3) Solder anode with anode and cathode with cathode of the batteries.
4) Battery pack is complete !
Step 3: Making the Circuit
1) Connect the cathode of battery to -ve terminal of TP-4056 and the step up module.
2) Then connect the Anode of all three as shown in the 3rd image.
3) Then adjust the output of step up module to 5V using the potentiometer
4) And at the end connect output of step up module to USB port.
Now you can charge your Mobile but ........
Step 4: But.....
You can use this circuit if your mobile uses less than 700ma
but I have an idea for that !
Step 5: Problem Solved ?
I used an pcb from old power bank which claim to have capacity of 10000mAh hahahahahahahaha not funny :p
Or
Use this DC 0.9 - 5V , 3V To 5V USB Charger Step Up Module Mini DC-DC Boost Converter
Step 6: Final Step!
1) I removed all the SMD LEDs and the Push button.
2) Then I soldered 5 mm white leds and a push button on the new wires.
Step 7: Congratulations !
Okay now our power bank is complete :)
dont forget to give it a thumbs up and do check out my YouTube Channel
https://www.youtube.com/channel/UC6Mfo-7o62yj3pStlJxh8sQ
Step 8: Thank You
If you like my work
Feel free to check out my YouTube channel for more awesome stuff: https://www.youtube.com/c/Nematics_lab
You can also follow me on Facebook, Twitter etc for upcoming projects
https://www.facebook.com/NematicsLab/
31 Comments
3 years ago
I made one very similar, thanks for sharing
https://youtu.be/8rCQwYouXSs
Question 4 years ago
What's the switch for? Can I skip it?
Question 4 years ago on Step 1
How to safeguard batteries from getting deep discharge? Is there any protection circuit that will defend batteries if we keep it connected to phone.
5 years ago
What is this 18650 cell ...
Insted of it Can i use my old mobile battery which is 3.8li polymer battery and 9.5Wh
5 years ago
any idea what is usage of the coil made with copper wire in the pcb?
Reply 5 years ago
its secret hi tech black magic stuff, but basically, if you have step up converter, coil + capacitor serve as "storage" for amplified voltage before its send to output, and yes, it must be there
6 years ago
Very nice
6 years ago
Thanks for the idea!
Can I attach more batteries in parallel? Will it affect the charging module?
Reply 6 years ago
Yes But charging time will increase by number of batteries attached one battry takes about 3 hrs to charge so dont freak out when you get high charging times its just normal
6 years ago
Very nice, might also want a step down converter and remember, some 18650 cells have built in current limiting and any up/down converter also has a current limit which may, or may not, limit the useful current even more.
Oh, just a friendly word hint, the English language is a real "pain" we have many words that sound alike and are spelled differently and mean different things. A real good example is, to, too, and two for one. :) The word "Patient" is a person under a doctor's care. The word you wanted to use was "Patience" meaning a person is tolerant, able to handle disappointment and continue.
Thanks again for posting your instructable! Also, your use of English is far better than mine would be of your language, please continue to post & expand you knowledge both of electronics and the painful English language. (Which most of us who speak English as a first language still mess up as well!)
Reply 6 years ago
Mine don't have inbuilt circuit protection. And thanks for telling mistake of Patient word. Actually Doing youtube and video editing is pain so some times I do mess up with it when tired
6 years ago
Nice work, I've been thinking about turning a large pile of excess 18650s I have into new guts for an old powerbank. Nice to see it already done. I'm going to use an aluminum project enclosure (and very careful isolation/shielding) to make mine a little more robust.
Thanks, good 'ible!
6 years ago
This is a wonderful project!!.. Thanks for sharing!....
6 years ago
Did you ever try to write in a foreign language yourself.
At least he's an enthusiastic person who makes something.
You have probably two left hands and you are jealous of him.
6 years ago
All nonsense..no protection circuit...you can damage your phone dude
Reply 6 years ago
If they are good quality batteries they should have built in protection but if they are cheap chinese batteries it would be good to have a dedicated usb input with the necessary protection in it
Reply 6 years ago
as long as the boost circuit is set to 5.2 volt they will be no damage and protection cirsuit is only needed for the first idea to stop over discharge
Reply 6 years ago
on my board there is TSP 2511 so i dont need to worry but second option needs to be worry
Reply 6 years ago
i only so the first half with the charge controller and the boost converter i had not scene the part of this tut where you use the salvaged unit so all my comments where to the diy unit not the salvaged unit
Reply 6 years ago
The board which I am using is having TSP 2511
check the data sheet . yes if you use the second one you will damage cells.
