Introduction: DIY Powerful Amplifier Using 2SC5198 and 2SC1941 Transistor
A transistor amplifier circuit is an electronic circuit that uses one or more transistors to amplify an input signal. The basic operation of a transistor amplifier circuit involves using a small input signal to control a larger output signal.
The input signal is typically too weak to be used directly, but the transistor acts as an amplifier to increase the signal strength. There are various types of transistor amplifier circuits, such as common emitter, common collector, and common base, each with different advantages and disadvantages.
Transistor amplifier circuits are widely used in electronics for applications such as audio amplifiers, radio receivers, and power supplies.
The final circuit diagram and design can be seen above. We also thanks to our sponsor JLCPCB https://jlcpcb.com/RTA for sponsoring us PCB for this project.
The article is being published in collaboration with JLCPCB. They supply high quality PCBs at a very reasonable price. They also can provide SMT circuit assembly.
We thanks to our sponsor JLCPCB https://jlcpcb.com/RTA for sponsoring us PCBs for this project circuit.
Thanks To JLCPCB.
$2 for 1-4 Layer PCBs.
Get SMT Coupons - https://jlcpcb.com/RTA
Step 1: Component List
To making this powerful amplifier circuit, we might need some electronics component.
All components list have been given below –
Component List –
1. PCB from (jlcpcb)
2. Transistor - C5198, A1941 and C2383
2. Resistor – 1 KΩ and 100 KΩ
3. Capacitor – 2200uF/25v, 470uF/25v and 220uF/25v
4. Diode – 4148
5. Audio Input Cable
6. Sound Speaker
7. Power Source - DC 12v
Step 2: Transistor Pin Out
C - 5198
The C5198 transistor is a bipolar NPN power transistor designed for high power audio amplifiers and switching applications.
1. Base
2. Collector
3. Emitter
A-1941
The A1941 transistor is a PNP bipolar transistor commonly used in high-power audio amplifier circuits and other high-voltage applications.
1. Emitter
2. Collector
3. Base
C-2383
The C2383 transistor is a PNP bipolar junction transistor commonly used in low-power audio and general-purpose amplifier circuits.
1. Emitter
2. Base
3. Collector
Step 3: Feature of Transistor Amplifier Circuit
1. High gain: Transistors can provide high voltage and current gain, which makes them ideal for amplifying weak signals.
2. Low distortion: Transistors have low distortion characteristics, which helps preserve the quality of the input signal during amplification.
3. Variable gain control: The gain of transistor amplifier circuits can be easily adjusted by changing the biasing conditions of the transistor.
4. High input impedance: The input impedance of a transistor amplifier is typically high, which helps prevent loading of the input signal source.
5. Low output impedance: The output impedance of a transistor amplifier is typically low, which enables the amplifier to drive a load with minimal loss of signal.
6. Small size: Transistor amplifier circuits can be made in small sizes due to the compact size of the transistors themselves.
7. Low power consumption: Transistor amplifier circuits consume less power compared to other types of amplifiers, making them energy efficient.
8. High reliability: Transistors are known for their high reliability and long life, making them suitable for use in various applications.
Overall, transistor made amplifier circuits are versatile, efficient, and reliable, making them a popular choice in many electronic circuits.
Step 4: Schematics and PCB Design
The schematics and design of PCBs can be seen above.
Step 5: Connect Resistor With Circuit
To make this powerful amplifier circuit, 1st we connect resistor with the transistor. We connect 1k resistor with "Base" and "Collector" leg of C5198 transistor. Then connect 100k resistor with "Emitter" leg of A1941 transistor and it's another terminal with "Base" leg of C2383 transistor.
Step 6: Connect Diode With Circuit
Now we need to connect diode with the circuit. We are using two pieces 4148 diode. We connect this diode positive terminal with "Base" leg of C5198 transistor. Then connect this diode negative terminal with another diode positive leg. Then connect it's empty terminal of another diode connect with "Base" leg of A1941 transistor.
Please remember that, we might need to connect C2383 "Collector" leg with "Base" leg of A1941 transistor.
Step 7: Connect Capacitor With Circuit
Capacitor is a part and parcel of an amplifier circuit. 1st we connect 470uF/25v capacitor negative leg with "Collector" leg of A1941 transistor and the capacitor positive leg with "Collector" leg of C5198 transistor.
Now we connect the rest capacitor with the circuit. We connect 2200uF/25v capacitor positive leg with "Emitter" leg of A1941 transistor.
Then connect 220uF/25v capacitor positive leg with "Base" leg of C2383 transistor and it's negative terminal will be empty.
Step 8: Connect Speaker With Circuit
For this sound system, we are using 4Ω-40 watt speaker. We connect this sound speaker one terminal with negative leg of 2200uF/25v capacitor and the other terminal with "Emitter" leg of C2383 transistor.
Step 9: Connect Audio Input Cable With Circuit
Now we connect audio input "R" cable with negative leg of 220uF/25v capacitor and audio input "G" cable with "Emitter" leg of C2983 transistor.
Step 10: Connect Power Source With Circuit
For power source we are using DC-12v. You also can use 12v battery or 12v power adaptor. We connect DC-12v positive terminal with "Collector" leg of C5498 transistor and DC-12v negative terminal with "Emitter" leg of C2383 transistor.
Step 11: Soldering and Cleaning
Neat and perfect soldering is an important part for all kind of PCBs. Since soldering, you should remember that, there should not be any kind of short circuit connection. After soldering all leg, we cut-off the extra leg of all electronics component.
We also can use liquid PCB cleaner to clean the PCB board.
Step 12: Steps to Order PCBs From JLCPCB
If you complete design of your PCBs, then it is time to order PCBs. To order best quality PCBs, just visit JLCPCB and click on the “QUOTE NOW” button.
Since 2006, JLCPCB continuously driven to become more efficient and to reduce costs. They promise to offer customers the most economic PCBs forever. JLCPCB makes cheapest but top quality PCBs possibly because of scale effect, extremely high production efficiency and less manpower cost.
You can order minimum 5 pieces PCBs for only $2 costs.
To order PCBs, make your Gerber file. Then drag and drop the Gerber file on the following box.
Click on “Gerber Viewer” button you can check the PCBs design. Make sure everything is good, then choose color, quantity and order your PCBs at very reasonable prices.
If you are a new user, then you can order 10 pieces PCBs, costing only $2. To place your order click on “Save to Cart” button. Confirm your shipping address and shipping method.
Step 13: Steps to Order SMT PCBs From JLCPCB
To order your SMT PCBs, visit JLCPCB.
1. Drag and drop SMT PCBs file on site.
2. Choose your PCBs color and quantity.
3. To free SMT assembly for your PCB click on “SMT Assembly” button and then confirm.
4. Add your BOM file and CPL file.
5. Place your order click on “Save to Cart” button.
6. Confirm your shipping address and shipping method.
7. Pay your payment
8. Wait for confirmation mail.
9. For SMT Service, Click here. (https://cart.jlcpcb.com/quote?orderType=1&stencilLayer=2&stencilWidth=100&stencilLength=100&stencilCounts=5)
Step 14: Shipping and Billing
JLCPCB supported all shipping method can be seen below.
Estimated Delivery Time
- DHL International Express 3-5 business days
- UPS Worldwide Saver 3-6 business days
- S.F Express (Standard) 5-8 business days
- S.F Express (Economy) 8-15 business days
- Singapore EMS 8-15 business days
- Post Link Registered Mail 15-20 business days
- ePacket 15-25 business days
- Registered Air Mail 15-20 business days
JLCPCB supported Payment method.
- PayPal
- Credit/Debit Care
- Prepaid wire transfer
Step 15: Confirm PCBs Order
To confirm your order, pay your payment. Then accept PayPal, Credit/Debit Card, and Prepaid Wire Transfer. To manufacture your PCBs, it’ll take about 2 days. DHL will be fastest shipping method to arrive your ordered PCBs at your location.
All PCBs were well packed and quality was really good.
Thanks to JLCPCB for best quality PCBs.
