DIY 3D Hologram Pyramid
Intro: DIY 3D Hologram Pyramid
In this Instructable I will teach you to make a very simple Pyramid to watch 3D hologram videos on your smartphone or tablet. All you need for this is some stationary and few minutes of time.It's a great item to your Halloween decorations! You can gift it to your loving one !
STEP 1: How It Works ?
It works on the principle of "Pepper’s Ghost". Four symmetrically opposite variations of the same image are projected on to the four faces of the pyramid. By principle of Optics ( An object in a mirror will appear to stand as far inside the mirror as it is away from the mirrors surface) , each side projects the image falling on it, to the centre of the pyramid. The 4 projections combined to form a whole figure which creates a 3D image.
Image source : Credit to Neon Society Electronics
STEP 2: Tools and Materials Need
STEP 3: Make the Templates
Draw a trapezium with size 60mm x 35mm x 10mm.
1. Draw a vertical straight line on the graph paper
2. Mark two dots at 3cm right and left from the vertical line.Then join them .( Base of the Trapezium )
3. Mark a dot on the vertical line 35mm above the base line
4.Draw a 10mm line parallel to base.Then Join them to make the complete Trapezium.
5. Cut out the templates with some margin on each sides.
Now your Template is ready.
STEP 4: Make 4 Trapezium Shapes
I used a clear plastic box for making the Pyramid Surfaces.
Stick the Template on the Clear Sheet. I used scotch tape to stick it.
Then Cut out the marked portion by using a scissor.
Repeat the above process to make remaining three shapes
STEP 5: Join the 4 Shapes
Place the 4 shapes as shown in the above picture.
Join the four edges to form a pyramid shape.
Stick them together by using clear tape.
Now you have made yourself a hologram pyramid !
STEP 6:
Open the Holographic Videos in your smart phone.
You can directly play it from YouTube.Here is the link.
Place the hologram pyramid in the middle of your phone screen like shown in the above pictures.
Align properly to get good result.
Don’t forget to switch off the lights in the room before you start playing the video.
Enjoy !!!
9 Comments
drew.lemmon 3 years ago
The "why" this works is because we are targeting a 45-45-90 right triangle. Precalculus: it's more than just school subject fodder!
PranavM25 7 years ago
cool project
CarlvinD 7 years ago
awesome
opengreenenergy 7 years ago
Mjtrinihobby 8 years ago
Vincent14 7 years ago
Hello, where does your pyramid proportions come from, please? Could you explain these choices? (sizes, angles)
Gursimran Singh 425 8 years ago
Gud One!! I too made a kind of it Beta type!!
opengreenenergy 8 years ago
Yours is also awesome.
