Introduction: DIY RFID Card Reader
RFID stands for Radio Frequency Identification a term that refers to technologies that use radio frequencies to identify objects. RFID has been used in a number of practical applications in many industries, such as improving supply chain management, tracking household pets, accessing office buildings, and speeding up toll collection on roadways. Being so useful & productive they do have a couple of shortcomings, such as not being cost effective to buy & repair due to the complex nature of the embedded MCU (microcontroller units) in RFID receivers. So in this project, we are going to go over a step by step procedure on 'How to make an RFID Card Reader Without Using An Arduino' or any other kind of microcontroller.
You can make this circuit on Printed Circuit Board PCB to Order
Custom-built PCBs at amazingly low rates 2$ for 5 PCB’s Please visit: www.jlcpcb.com
Step 1: Hardware Required
- Comparator IC LM324
- NPN Transistor BC494, 2N2222
- Buzzer
- Variable Capacitor 33pF
- Enameled Copper Wire 25/16 gauge
- Pushbutton
- Zener Diodes 1N4148
- LED
- Capacitor 10pF, 82pF, 27pF, 100uF
- Resistors 82K, 1K, 2.2M, 100K
Step 2:
Solder the 10pF & 82pF capacitor parallel to the 82KOhm resistor.
Step 3:
Solder the 1K resistor in series to the 82pF capacitor.
Step 4:
Coil the 25 guage copper wire till 6 turn & solder one end with the collector of the transistor & other with the 27pF capacitor.
Step 5:
Solder the pushbutton & the coin cell on the Veroboard.
Step 6:
Solder the LM324 Comparator IC on the Veroboard. after that, solder a 100uF capacitor between pin 4 (+ve) & 11 (-ve) of the IC.
Step 7:
Connect 2.2M Ohm resistance between pin 1 & 2 of the IC. After that attach a 100K resistor between pin 2 & pin 3 of the IC.
Step 8:
Solder a 33pF variable capacitor between pin 2 & 3 of the IC & a 10pF capacitor in series to the variable cap.
Step 9:
Connect the +ve pin of the LED on pin 1 of the IC. Connect the base of the 2n2222 transistor to the -ve terminal of the LED with a 1K resistor.
Step 10:
Connect the -ve terminal of the 5V buzzer to the collector of the
transistor & connect the +ve terminal to the +ve of the 1N4148 zener diode.
Step 11:
Connect a coil of 25 guage copper wire between the 10pF capacitor & the emitter of the transistor.
Step 12:
Connect the +ve of the battery to pin 4 of the IC & -ve to the pin 11.
Step 13:
Power up & test the circuit
