Introduction: DIY Radar
🔎 Introduction
Radar systems are widely used in defense, aviation, automotive, and robotics to detect and track objects within a certain range. While real radars use radio waves, we can replicate the concept at a small scale using ultrasonic sensors and visualize the data on a computer.
In this project, we will build a DIY Ultrasonic Radar System using Arduino, an ultrasonic sensor (HC-SR04), and a servo motor. The ultrasonic sensor continuously scans an area from 0° to 180° by rotating on the servo. At each angle, it measures the distance to the nearest object and sends that information to a computer via serial communication.
On the computer, we use Processing IDE to create a radar-like interface. The interface simulates the sweeping motion of a radar and plots detected objects on the screen in real time:
- The green line represents the sweeping beam.
- Red markers represent detected objects within a set range (e.g., 40 cm).
- A HUD (Heads-Up Display) shows angle, distance, and range values.
This project combines hardware (Arduino + sensors + servo) and software (Processing visualization), making it an excellent beginner-to-intermediate project for learning about:
- Sensor interfacing with Arduino
- Servo motor control
- Serial data communication
- Data visualization in Processing
Not only does this project demonstrate how radars work at a conceptual level, but it’s also a fun and interactive tool you can build at home. You can use it as a mini security scanner, obstacle detector, or robotics project.
By the end of this tutorial, you’ll have a working ultrasonic radar that detects objects in its field of view and displays them on your computer in real time.
Step 1: Gather the Components
You’ll need:
- Arduino UNO / Nano / Mega
- Ultrasonic sensor (HC-SR04)
- Servo motor (to rotate the ultrasonic sensor)
- Breadboard + jumper wires
- USB cable (to connect Arduino to PC)
- Computer with Arduino IDE and Processing IDE installed
Step 2: Wiring the Components
- Connect HC-SR04 to Arduino:
- VCC → 5V
- GND → GND
- Trig → D10
- Echo → D11
- Connect Servo motor:
- VCC (Red) → 5V
- GND (Brown/Black) → GND
- Signal (Orange/Yellow) → D9
(Adjust pins if you use different ones, but update the Arduino code accordingly.)
Step 3: Upload Arduino Code
Open Arduino IDE.
Paste the Arduino sketch that:
- Rotates the servo from 0° to 180° and back.
- Uses the ultrasonic sensor to measure distance.
- Prints angle,distance. over Serial.
Select your board (UNO/Nano) and correct COM port.
Upload the sketch.
Step 4:
- Download and install Processing IDE: processing.org/download.
- Copy the Processing sketch (radar_visualization.pde) into Processing.
- In the code, set the right COM port for your Arduino:
- Run the Processing sketch.
Step 5: Visualize the Radar
he radar sweep will appear on your computer screen.
A green sweep line rotates from 0° to 180°.
If an object is detected within 40 cm, a red marker will appear on the radar.
HUD text will display angle and distance in real time.
