Introduction: DIY Reversal Lens Macro Rig
Reversal rings are one of the most fun toys for any photographer. This will work on any SLR camera(as long as it can shoot with a t-mount). Auto focus will not work with this. My main goal is to use almost everything a normal photographer has laying around. Almost everyone has a busted lens, a t-mount and filters that aren't being used why not put them to an amazing use!
Step 1: Materials
I am keeping this materials list simple.
Materials:
1 tube of Mighty Putty"
Skylight or UV Filter (My target is 58mm which is a common Canon size)
(You can use a busted filter if you take the glass out but you will run into dust problems)
subjects (bugs, flowers, food, etc)
Lens that matches the filter size
(I recommend an older lens because the rear element will be exposed)
Tools:
Canned air for cleaning area and all parts
Materials:
Tools:
Step 2: Center of Being
Center the filter with the male threads up on the T-mount. I HIGHLY recommend using a filter with glass just because of the exposure of your sensor to dust. If you do not have a dust removal system then you WILL have to clean your sensor often.
Step 3: Knead!
Break off this big of a piece of mighty putty and knead it till the color is as shown and the green is completely gone.
Step 4: Billy Would Be Proud!
Roll your putty into a nice strip about 1/4" thick.
Wrap it around the filter/t-mount and break off the excess.
Press it around both of them to get it nice and tight.
Make sure there isn't any on the bottom part that connects to the camera because that will be flush on the mount. You also need to leave a little room for your lens to thread on. If your lens is broken like mine you can just put the lens on and permanently affix it.
Step 5: Hurry Up and Wait!
Step 6: Practical Application
Our finished lens is great fun! I live in Michigan so I have to buy decent subjects. I chose a ripe Starfruit. With this lens the wider the angle the greater the magnification. My test shots were shot at 28mm which is the greatest possible magnification with this lens. The depth of field is extremely shallow with this. I used an automatic lens so I could not change the aperture. If you use a manual lens you would have full aperture functionality. This lens doesn't require a ton of light. My shots were done hand held with a studio light. In normal sunlight outdoors these are very effective.
