Introduction: DIY Rock Tumbler
The kind of tumbler I've seen before seemed like a fairly simple arrangement - some kind of barrel turned by horizontal rollers, similar to a tumble dryer, so that's what I set out to build.
Step 1: Parts List
Parts list - these parts all came from my junk pile. Nothing was purchased for this project, so technically it cost $0 to build. As suggested by several people (iceng and ottwafm), the tumbler would be more durable if some kind of wheel bearings were used for the rollers. Bearings for skate board wheels or ride-on mower decks should be easy to find locally.
1) electric motor from Grand Am electric window lifter.
2) old PC power supply. This one happens to be a 90W supply.
3) rollers - could be broom handle or any round pole. These are actually mini rolling pins from my wife's craft supplies.
4) various bits of wood to make a frame and base board.
5) 2 inches of garden hose.
6) power switch.
7) screws, coach bolts w/ nuts
8) anti-slip shelf liner
Tools required:
1) Saw
2) Screwdriver
3) Drill + appropriate sized bits
4) Wrench
5) Sharp knife
6) Soldering iron (or use crimp-on spade connectors)
Step 2: Initial Sizing
Step 3: Motor Mount
The motor is built into its own mount, which is offset from the side of the motor, so I cut a shim out of a piece of scrap plywood.
Step 4: Static End
Step 5: Check the Spacing
Step 6: Frame Assembly
Mount the motor along with the driven roller. I used coach bolts, which present a rounded head in the roller section.
The roller ends have a small amount of furniture finishing wax applied, to reduce friction in the holes.
Step 7: Wiring
Next, take one of the flat, 4 pin connectors and clip off the yellow (12 volt) and black (ground) wires. Solder those to the motor. I cut away the connector shroud to be able to get the soldering iron into it. Again, spade connectors would work, as would the proper connector if available.
Plug in the power supply, flip the switch and watch the roller turn!
Step 8: Tidying Things Up a Bit
2) screw the frame to the baseboard.
3) secure the power supply. I had a length of pipe hanging strap available, which also sufficed to hold the power switch. I oriented the power supply with the fan blowing towards the motor to provide cooling.
4) I had some spare storage drawers that just happen to fit nicely on the other end of the base board.
5) tests showed that the barrel would sometimes slip, which is why the rollers are now covered in anti-slip shelf liner.
