Introduction: DIY Rotary Moulding Machine
About: I'm an inventor , artist, machinist , welder . Knife Maker , Blacksmith, follow me on Instagram at bonifabcustom or watch my builds on YouTube at Bonifabcustom
All frame work was mig welded and made from either 2"x2" tube or 1"x2" steel tube.
Step 1: Welding Frame Top
Step 2: Welding Frame Bottom
Step 3: Welding Frame Bearing Support
Step 4:
Step 5:
Step 6:
Step 7: Idler Sprocket
Step 8:
Step 9: Welding Frame Rotary Mount
Step 10:
Step 11: Rotary Main Shaft
Step 12:
Step 13: Primary Chain
Step 14:
Step 15: Main Rotary Frame Work Completed
Step 16:
Step 17:
Step 18: Main Frame Done
Step 19:
Step 20: Heat Shield Installation
Step 21: Sheet Metal
I covered the walls by welding sheet metal to them.
Step 22: Insulating
I insulated it with compressed rock wool that I bought from the hardware store
Step 23:
Step 24: Exhaust for Excess Heat
Step 25: Fibre Glass Door Seals
I used high temp silicone to glue the seals onto the frame this helped the heat stay in.
Step 26: Insulated Machine Ready to Run
I used a 1750rpm motor and a 50:1 gear box , the unit is heated by a diesel space heater that brings the internal heat to 400 deg F in about 10 min .
Step 27: 50:1 Ratio Motor and Gearbox
Step 28: First Part Out of Machine
This part used 5lbs of low density poly ethylene pellets at 400deg F for about 40min heat time and 10 min cooling time .
Step 29: Part
Step 30: Finished Part
