Introduction: DIY Rotating Spice Bottle Keeper – a Smart Space-Saving Solution in Your Kitchen
About: FUN DIY, CRAFTS, EXPERIENCE THE JOY OF DOING IT YOURSELF. OFFICIAL CHANNEL.
Struggling with spice jars cluttering your kitchen? What if you had a stylish and functional way to store them while keeping them easily accessible? This DIY Rotating Spice Bottle Keeper is a perfect addition to any kitchen, giving a sleek, space-saving solution for organizing spices neatly. Let’s build this creative and practical spice organizer!
  1. Glass spice bottles with lid (preferably identical in size)
  2. Circular sun-board base
  3. Compass
  4. Strong adhesive & sealant
  5. Spray paint or varnish (optional, for finishing touch)
  6. Spices
Step 1: Preparing the Base
  1. Place a square sheet (wood, MDF, acrylic, sturdy cardboard or sun-board) on a flat surface.
  2. Use a compass to draw a perfect circle of the desired diameter. Ensure the size is large enough to accommodate the spice bottles.
  3. Carefully cut along the marked circle.
  4. Find the exact center of the circle and mark it.
  5. This will be the point where the central support rod or rotating mechanism will be installed.
Step 2: Make It Sturdy
  1. Place the two sun-board sheets on top of each other, ensuring they are perfectly aligned.
  2. Apply the adhesive evenly around the surface of the bottom sheet.
  3. Place the top acrylic sheet onto the glued surface and press firmly.
Step 3: Installing the Central Support
  1. Take a small cylindrical wooden block to act as the base support.
  2. Use a small glass jar lid or a metal disc as the rotating mechanism.
  3. Fix it on top of the wooden block using hot glue or strong adhesive.
  4. Make sure it's centered properly for balanced movement.
  5. Once attached, place the sturdy acrylic sheet over it.
Step 4: Creating the Bottle Holders
  1. The curved cutouts are made to snugly fit standard-sized spice bottles, preventing them from tipping over.
  2. Sun-board provides a lightweight yet firm base, making it ideal for supporting the bottles while maintaining the structure’s durability.
  3. The circular design ensures that when placed on the rotating base, the bottles remain balanced and accessible from all angles.
Step 5: Fixing the Bottle Holders
  1. Place the bottle holder cutouts on the rotating top platform.
  2. Ensure they are evenly spaced to maintain balance when bottles are added.
  3. Gently rotate the tray to ensure the bottle holders do not wobble or tilt.
Step 6: Adding Stability and Balance
  1. A circular sun-board piece is cut and shaped to fit between the base and the rotating platform.
  2. The round sun-board piece is placed between the two main platforms, aligning it centrally around the existing cylindrical column.
  3. The support ring is glued or fixed in place using adhesive, ensuring a firm grip while maintaining a lightweight yet sturdy build.
Step 7: Applying Colours
  1. Spray in smooth, even strokes, moving side to side.
  2. Apply multiple thin coats instead of one thick coat to prevent drips.
  3. Allow each coat to dry before applying the next (usually 10-15 minutes).
  4. For a glossy finish, add a clear topcoat after the final layer dries.
Step 8: Filling Spices in Bottles
  1. Slowly pour the spice into the bottle, tapping it gently to settle the contents.
  2. Tightly close the lid to maintain freshness and store the bottles in a cool, dry place.
Step 9: Final Outcome
"And there you have it – a Rotating Spice Bottle Keeper that keeps your kitchen tidy and stylish! No more searching for spices in cluttered cabinets. With a simple spin, you can access everything instantly. Try making this yourself and bring efficiency to your cooking space!
