Introduction: DIY Row Counter
Step 1: What You Need
A long piece of string- about 2 1/4 feet
20 big hole beads
20 big hole beads
Step 2: String Tying
Fold yarn in half and make a loop on the top by knottting. Knot should be a little bigger than your knitting needle
Step 3: Adding Beads
Take a bead and with one end of the yarn put it through the bead, then use the other end of the yarn and put it in through the side of the bead where the other yarn came out and pull
Continue this method until you have used all your beads
IF YOU HAVE TO DO MORE ROWS THAN 20 ADD MORE BEADS
Step 4: Tie Off
Make sure the strings are tight in between the beads Tie a knot joining the string together and leave a little space (just a LITTLE)
Step 5: How to Use
Use by moving a bead down every time you complete a row making a space in between the beads. How many beads are on the side your are moving them is how many rows you have done
