Introduction: DIY - Save ~$200 and Replace Dash Cluster Bulbs W/LEDs
The car dealer wanted over $200.00 (Parts and Labor - most of it labor) to replace the light bulbs in the instrument cluster of our 2001 Voyager.
If you follow these instructions, you can do it yourself for about 20 minutes of your time and ~$22.90 in parts. Also, once you replace the bulbs with LEDs, you shouldn't ever need to replace them again. This picture is of one of the new LEDs connected to a 12V power source.
I got the idea for this instructable from a 2007 forum posting at http://forum.chryslerminivan.net/showthread.php?t=6856 which provided the basic instructions on how to disassemble the dashboard.
Step 1: Parts and Tools
The LEDS:
The instrument cluster of the 2001 Voyager needs 8 bulbs. The replacement bulbs are PC74 (a #74 bulb with a twist-lock holder for mounting). I ordered QTY - 10 of #T1.5-B Blue LEDs (8 plus a couple of spares) from http://superbrightleds.com. They have LEDs for just about any vehicle, and not just dash bulb replacements, but others as well.
Tools:
A small pair of needle nose pliers - to twist out the old bulbs and install the new LEDs
#1 Phillips screwdriver(s) (short and long reach) or a combo type with a drive extension (preferably with a magnetic tip).
Small flat blade screwdriver - for prying a cover later.
Step 2: Getting Started
Make sure you have a small container of some kind to store the LEDs and the screws that you're about to remove.
Also, adjust the tilt the steering wheel as far down as it will go and WITH THE VEHICLE OFF and the PARKING BRAKE APPLIED move the gear shift lever to its lowest position. This will help in later steps, providing better access and some wiggle room for the dashboard cluster.
In this step there are two(2) Phillips screws that need to be removed. They're located under the upper edge of the instrument cluster bezel. Remove these two(2) screws and set them aside.
Step 3: De-bezelling the Dash
Now, to get at the next two(2) screws, you'll need to remove the small plastic panel located over the steering column. It's best to see the pictures for this step. Just pull up slightly at the front edge of the panel above the middle of the steering column and use the flat bladed screwdriver between the panel and the bottom of the bezel bracket to disengage the panel from the plastic retainer.
The panel will be snapped back in place later. Be careful when removing the panel, it has some small "fingers" that form slots at the rear corners of the panel.
Step 4: De-bezeling Part 2
With the panel removed from the previous step, you can now see the last two(2) screws in the bezel that need to be removed. They're just to the right and left of the green retainer pin in the photo.
Remove the screws and carefully pull the bezel assembly out of the dash. What worked best for me was to tip the top edge of the bezel out first and the shift it around a bit to completely remove it from the Dash board.
Step 5: Don't Stop Now...
With the bezel removed the rest is pretty easy. First off, there are four(4) more of those black Phillips head screws to remove, an upper and a lower screw on both the right and left sides of the cluster.
Go ahead and remove the screws and set them aside with the others, don't worry, if it's like mine, all eight(8) screws are the same.
NOTE: do not remove the two(2) small silver Torqs screws located just below the lower Phillips screws on either side of the instrument cluster. They can stay in place for this procedure.
Now here's where I deviated a little from the forum instructions. I didn't have to disconnect the cluster from the cable harness. Just tip the cluster forward slightly and you'll see the cable connector at the top rear of the cluster, just behind the Tach gauge. I was able to get enough slack in the cable harness that I could pull the cluster out and get access to the back, where the bulbs are located.
This is handy for another reason, since the LEDs are polarized, I was able to check them with the ignition on, to make sure that I got each new LED in correctly while I was installing them.
Step 6: Switching Out the Bulbs
With the instrument cluster now flipped around backwards, it was easy to twist the old bulbs out (counter clockwise). They might be a little tight, this is where the needle nose pliers come in handy. Just grasp the base of the the bulbs and turn them counter-clockwise about a 1/4 turn.
Now, with the ignition on and the vehicle lights turned on, insert each LED with the pliers, (if needed) turning them a 1/4 turn clockwise in the sockets and verifying that each one is working, before moving on to the next. If they don't work the first time, take them out, turn it a 1/2 turn and try again. The polarization of the LED means that they'll only work with the correct (+) & (-) connections. All of the LEDs that I installed had the white dot marking on the base of the LEDs pointed toward the top of the instrument cluster.
A good tip here is, even if all the bulbs weren't burned out, you should just replace them all, and then never have to go through this again.
Step 7: Putting It All Back Together
With all the new LEDs in place and working, let's get the dash put back together. We'll just go back through the previous steps in reverse order.
1) Flip the instrument cluster back around, the right way, and re-attach it with the four(4) screws.
2) Inset the bezel back into place and re-attached it with the other four(4) screws.
3) Replace the steering column cover by slipping those fingers into the slots at the lower rear of the bezel bracket, and then hinge the cover down onto the retainer and snap it back into place.
That's it, all done in less than 30 minutes (if everything went well).
Step 8: LED-ified Instrument Lighting
The result is a brightly illuminated instrument cluster. Pat yourself on the back, you just saved yourself ~$200.00 with this Do It Yourself project and your dash board is ever so slightly more efficient and running cooler with the LED lighting.
Epilog Challenge
25 Comments
7 years ago
I did this just yesterday. FYI, most automotive (if not all) LED PC74 bulbs have resistors integrated otherwise it would be too much of a hassle to purchase. All the bulbs worked fine until today. The socket with thw previously burnt out bulb stopped functioning. And now the gauges are not functioning. Either the circuit board under the main fuse box is corroded or the plug was loose behind the gauges.
8 years ago on Introduction
Just a heads up...
You may want to look into adding resisters to those LED's since these circuits weren't designed for those components as OEM. There are sites that will give you the R values needed when you plugin the diode spec and circuit nomenclature (which you should be able to follow through each trace).
10 years ago on Introduction
Not mentioned in these instruction, but something I encountered on my 2002 Voyager is a second cable connected to the back of the instrument cluster. The wire harness mentioned in step 5 has plenty of slack, but the other cable (speedometer cable?) which was connected to the lower right corner (backside) of the assembly had little or no slack. So it was difficult to get to the bulb on the right side (temperature gauge), but I did manage to get to it. I also removed the plastic steering column cover which made it easier to pull out the cluster. It is held in place by 3 screws on the underside.
11 years ago on Step 2
hey, great instructable, but just as a caution, I noticed that you said to put the gear shift in the lowest position. It is probably safe to say, either you were on fairly flat ground, you were on jack stands, or you put the parking brake on. The last one I mentioned is probably the safest idea to add to this or any automotive instructable, especially in case your or anyone else's vehicle is like mine. As they say, better safe than sorry right?
Reply 11 years ago on Step 2
Yes, you're absolutely right, if fact I changed this step today (10/13/2012) to add the note about applying the parking brake.
Thanks
12 years ago on Introduction
Well, I guess I was wrong, something has started to happen to the LEDs that I installed. I'll update this project (or possible start a new one) to replace the LEDs. The first symptom that we noticed was that some of the LEDs are intermittently going on/off.
Reply 12 years ago on Introduction
Did you find out why the LEDs were going off and on? Was there a problem with the LEDs or some other issue you can help me avoid?
Thanks! Ed
Right, here's what I found: of the 8 original LED "bulbs" that I installed, two had gone bad (one didn't light at all on the test bench and the other was very weak). I had pre-tested these LEDs before I installed them, and I had even ordered a couple extra, just in case. I suspect that a third bulb just wasn't seated properly or had worked itself loose. The way these "bulbs" are constructed (see the third picture in this Instructable - in the Parts and Tools step) could make for a loose connections if the + or (-) connections don't make good contact. Make sure the little +/(-) tabs are flexed up toward the tip of the "bulb" prior to installation. When you install them, give them a little back and forth twist to scratch the contact surface of the circuit board (instrument panel) to make a good connection. Hope that helps, and good luck with your project.
Thanks for the info. It's very helpful. So in the end, once you got 8 good LEDs, everything worked out fine? Thanks again!
Reply 11 years ago on Introduction
Yes, 8 new, slightly brighter, LEDs are now installed and so far no symptoms of the previous failures.
14 years ago on Introduction
How does this save $200, is it the price of the other bulbs? or is it something else?
Reply 14 years ago on Introduction
Exactly what I thought! One can save about $200 by replacing old bulbs with new ones, instead of asking car dealer to do it. I don't think replacing bulbs with LEDs instead of bulbs, is much cheaper (little, but not much). So savings come from DIYing the job, not from using LEDs.
You also save with LEDs because once you've got them working, they should never have to be replaced. I think the OP might have gone with a more DIY approach, adapting his sockets to use bare LEDs with dropping resistors, but still a substantial savings over what a dealer would charge.
If I were rich and could find an honest mechanic, I'd never turn another wrench, but neither condition has yet been met. Firestone 'noticed' that my radiator hoses were 'soft' when they did an oil change. The estimate for replacing the hoses and flushing the cooling system was $300.
I could do that job--had it really needed doing--for about $30...in less than an hour.
The dealer wanted approx. $240.00 for the parts and labor to do the bulb replacement (and they would have just used the standard bulbs). Others can attest to this pricing on the forum that I got the procedure. The bulbs at the dealer where around $6 ea., the LEDs were only $1.79 ea. (and I paid $5 for shipping). Hope that helps.
ledwholesalers.com
The manufacturer replacement bulbs are PC74 (a #74 bulb with a twist-lock base for mounting). I ordered #T1.5-B LED "bulbs" from superbrightleds.com, described as; "T1.5 instrument LED bulbs consist of a T1-1/2 (#73/74) standard miniature wedge LED bulb installed in a twist lock socket base 12 Volt DC - 100 degree beam pattern". I can't say for sure if the B8.5Ds or NeoWedge LEDs would work or not. PS: If you liked this Instructable, please be sure to give it a rating and vote for it in the Epilog Challenge contest. Thanks.
I got the lights replace in the center console and they really are a lot brighter than the OEM. Now on to the gauges. Thanks
Thanks again, now I've got the bezel off of the center console but I acn't figure out how to get the 3 wireing plugs out of their sockets. Does something have to be squeezed to release them. There is a red clip in each plug that looks movable.
It sounds like yours is a slightly different model, mine only had one wiring harness and I didn't end up disconnecting it, because I had enough slack in the cable to turn the instrument cluster around to replace the bulbs.
