Introduction: DIY Seedplate for BIP39 Words
I searched for a safe, fireproof and easy way to store my 24-BIP39-Seed-Words of my cryptocurrency wallet.
I don't wanted to pay much money for a pre-printed steel plate as offered on some sites, so I decided to make a template by my own to create a durable storage for under 15€.
What you need:
- Metal-plate of your favour 20cm x 10cm x 2mm
(example:. V4A - AISI 304 steel plate)
(~5€)
- Center punch and a hammer
or an automatic center punch
(~8€)
- Soft pencil
- some tape
- a printer for printig the template
Time to create: ~ 30 Minutes per 24-word-plate
Step 1: Mark Your Words
Print template below two times without resizing and mark the first 5 letters of each word.
As the first four letters are unique in the BIP39 list: 5 letters are enough.
Edit 2-2021: Added an improved version of the template: Now with letters in the boxes.
Step 2: Tape and Punch
Cut out the template and fix with tape on the metal plate.
Punch all your dots and +-marks in the corners.
Reverse the plate if you have a 24-word-phrase. Mark the ++-marks on the bottom to mark on wich side you are.
Pull off the template-paper.
Step 3: Decode and Checking
Print template on foil, aling at the +-marks and read your words.
If correct punched: Burn your marked paper-template.
or
Put a fresh template-print on the plate. Push a pencil through the +-marks in the corners to align.
Fix with some tape an make a hatching with a soft pencil: Your punced holes appear as small dots on the paper.
Now you can store the plate on a save place and nobody will know what it is and you can sleep well.
Feel free to comment what could be improved.
Thanks for reading!
Anything Goes Contest
2 years ago
What a neat idea! Thank you for sharing it :-)
