Introduction: DIY Smart Plant Watering System for Indoor Gardens
Are you tired of forgetting to water your indoor plants? Or do you want to ensure they get just the right amount of water? This project will guide you through creating a DIY Smart Plant Watering System using basic electronics and sensors. This system will automatically water your plants based on soil moisture levels. You can build this project using easily available components like an Arduino, soil moisture sensors, a water pump, and a relay module.
- Arduino Uno
- Soil Moisture Sensor
- Water Pump (with tubing)
- Relay Module
- 12V Power Supply
- Jumper Wires
- Breadboard
- A plastic container for water storage
- Potting soil and plants
- Small PVC pipes or plastic tubing for water distribution
Step 1: Set Up the Soil Moisture Sensor
- Insert the soil moisture sensor into the plant pot where your plant is growing.
- Connect the sensor’s VCC pin to the 5V pin on the Arduino.
- Connect the GND pin of the sensor to the GND pin on the Arduino.
- Connect the sensor’s output pin to one of the analog pins on the Arduino (e.g., A0).
Step 2: Connect the Water Pump With Relay Module
- Connect the water pump to the NO (Normally Open) and COM pins on the relay.
- Connect the VCC and GND of the relay module to the 5V and GND pins on the Arduino, respectively.
- Connect the relay’s signal input to a digital pin (e.g., D7) on the Arduino.
Step 3: Writing the Arduino Code
int sensorPin = A0; // Soil moisture sensor connected to A0
int relayPin = 7; // Relay module connected to pin 7
int sensorValue = 0;
void setup() {
pinMode(relayPin, OUTPUT);
digitalWrite(relayPin, HIGH); // Turn off the water pump
Serial.begin(9600); // Begin Serial communication for debugging
void loop() {
sensorValue = analogRead(sensorPin); // Read moisture level
Serial.println(sensorValue); // Output the value for debugging
if (sensorValue < 400) {
digitalWrite(relayPin, LOW); // Turn on water pump if moisture is low
} else {
digitalWrite(relayPin, HIGH); // Turn off the pump if the soil is moist enough
delay(1000); // Wait for 1 second before checking again
Step 4: Assemble the Water System
- Use PVC pipes or plastic tubing to direct the water from the pump to the plant pots. Ensure the tubing is securely fastened to the pump output and positioned to drip into the plant’s soil.
- Place the water pump inside a plastic container filled with water.
Step 5: Testing the System
- Power up the Arduino and the relay module using the 12V power supply.
- Place the soil moisture sensor in dry soil, and the water pump should automatically turn on.
- Once the soil becomes moist, the pump will turn off.
You now have a fully functional smart plant watering system! This DIY project helps keep your plants healthy by ensuring they are watered just the right amount. It is a great way to combine gardening with technology.
