Introduction: DIY SmartPhone Controlled RGB Led WS2812
I am going to show you how to make SmartPhone Control RGB Led WS2812 . You Can change Led Colour , Brightness ,On/Off & also make different designs & patterns.You can use mobile , tablet , pc anyone supporting browser. For this you just need a Nodemcu.
Step 1: Components Needed
1. NodeMcu
2. RGB WS1812B Led strip
3. Power supply 5 volt
Step 2: Connection & Assembly
You need to connect WS1812B strip as per diagram . To form the triangle cut led strips in 3 equal size i.e. 20 led each. Always cut in the dotted line. Then solder it . Next upload the code to Nodemcu. You need separate power supply 5 volt for Led strip. Check video for details.
Step 3: Download Code
You can download code here
