Introduction: DIY SmartPhone Ring Light
Although I usually do all photography/video work on a dslr, I wanted an easy way to light my subject evenly with my smartphone. This ring light is super easy to build and requires very few materials. You'll be able to complete this project in under half an hour. Hope you enjoy!
Step 1: Tools and Materials
TOOLS-
-Ruler
-Scissors
-Soldering Iron
MATERIALS-
-Phone case (got mine from ebay for 2 bucks)
-9v battery
-9v battery connector clip
-Tinned copper wire
-White LED strip
-Solder
-Switch (can be any switch, I used a slide switch)
Step 2: Cutting the LED Strips
-Cut the LED strips into 4 strips
-There should be markings every 3 leds or so indicating where to cut
Step 3: Cutting and Bending the Tinned Copper Wire
-Cut 8 strips of tinned copper wire, each measuring about 2cm
-Bend each strip to a right angle as shown
Step 4: Soldering the LED Strips
-Solder the tinned copper wire to the LED strips as shown, be sure to solder together the positive to positive and the negative to negative
-Continue soldering the tinned copper wire to the LED strips until you form a square that looks like the picture
Step 5: Cutting, Connecting, and Soldering the Battery Clip
-Cut the 9v Battery connector leads similar to what is shown in the picture
-Solder the positive wire to one lead of the switch
-Solder the remaining positive wire you cut off the battery connector to the other lead of the switch
-Solder the negative wire and positive wire of the battery clip to the corresponding tinned wire of the LED strip square
Step 6: Applying the Components to the Case
-Use double sided mounting tape to apply the switch and battery
-Use the adhesive backing of the LED strip to apply it around the phone camera
Step 7: FINISHED
You are now finished, get out and shoot!
Step 8: Notes
-In the event your LED strips do not work, make sure your polarity is correct and your solder joints are secure
