Introduction: DIY Smartphone Video Rig
In this video I'm showing how to make a DIY Smartphone/iPhone Video Rig.
On this Rig you can mount your microphone and other accessories and this will also help you to film more stabilized.
Part list:
- Aluminum Flatbar 20x3mm L=260mm (2 pcs)
- M6 threaded rod L=145mm (2 pcs)
- Bicycle grips
- M6 nut (4 pcs)
- M12 nut (4 Pcs)
- M6 nyloc nut (4 pcs)
- 1/4" bolt + washer (2 pcs)
- Smartphone mount https://www.amazon.com/Manfrotto-Universal-Smartp...
Step 1: Aluminum Flat Bar
Cut to two pieces of the aluminum flatbar. L=260mm
Drill one 6,5 mm hole in each end and one hole in the middle.
Step 2: Round the Edges With a File.
Step 3: Paint the Flat Bars and Let Them Dry
Step 4: Nut in Nut
Put the M6 nut in the M12 nut and hitt is with a hammer or press it with a vise.
Step 5: Cut the Threaded Rod
Cut two pieces of the M6 threaded rod about 20 mm longer than the bicycle grips and screw on the M6 / M12 nuts, one at each end, to match the length of the grips.
