Introduction: DIY Snoopy House Wooden Snack Box | Laser Cut, Custom Wood Art, Box
About: This is Alex from NEJE. Love to make some crafts with it and share the crafts I made.
Craft a delightful Snoopy-themed snack box shaped like his famous red doghouse with a flip-top lid, perfect for storing snacks! This DIY project uses laser-cut plywood to create a functional and whimsical storage solution. With a laser cutter, paint, and basic assembly, you can replicate the cozy design featuring Snoopy and Woodstock atop the lid.
Materials:
  1. 3mm thickness plywood * 2 (50*40cm)
  2. Wood glue
  3. Acrylic paint (red, white, black and yellow recommended)
  4. Sandpaper (optional, for smoothing edges)
Equipment:
  1. 20W NEJE Laser Cutter
  2. Software: Lightburn
Step 1: Upload the Design File
Download and upload the file. Ensure the design fits a 50*40cm work area in Light burn. The file is match any 3mm wood thickness.
Step 2: Laser Cutting
Place the 3mm plywood into the laser cutter and start to cut. Align the file to the work area and cut all parts in one pass if your machine supports the area; otherwise, split into multiple passes.
  1. Cutting: Speed: 450mm/min, Power: 90%, Air Assist: On
  2. Engraving(Line): 5000mm/min, Power:70%, Air Assist: Off
Step 3: Painting
Sand the cut edges lightly if needed for smoothness. Paint the pieces before assembly:
  1. Roof and Walls: Paint red to match Snoopy ’s doghouse.
  2. Snoopy and Woodstock: Use white and yellow for bodies, black for outlines,
  3. Door: Paint black.
Allow the paint to dry thoroughly to prevent smudging.
Step 4: Assembling the Snack Box
Secure the roof to the main body, ensuring the lid opens and closes smoothly. Glue the side walls to the base with wood glue, ensuring a sturdy structure. At last glue Snoopy ears and the arched door in place.
Step 5: Enjoy Your Snack Box
Fill the box with your favorite snacks, close the flip-top lid, and enjoy your custom Snoopy house snack box! The red design with Snoopy and Woodstock adds a playful touch, making it a great addition to your kitchen or living room.
Note: If you feel that the lines on the house are not obvious enough after coloring, you can paint them black like the third and forth.
