Introduction: DIY Snow Foam Pressure Pump
This Instructable will show you how to change ordinary garden pressure pump in a snow foam pump.
Feel free to help improve this instructable.
Regards.
Step 1: What You Will Need
Things that you will need:
-Pressure pump 1.5 or 2L
-2 luer lock syringe 10mL
-Something to cut (scalpel/knife..)
-Scissor
-Plies
-Wrench
-Flat spray nozzles F110 (015, 02, 03, 04, 05)
-Needle to puncture
-Glass wool
-Sponge, optional to decrease the water flow
Step 2: Disassemble the Original Nozzle/tip
With the wrench and your hand do a small pressure to remove/tear the tip off
Step 3: Syringe
*Test if the tip will fit in the pressure pump.
Step 4: 1st Syringe
1st Syringe do as the pictures
Cut the "tail" and enlarge the tip
Step 5: 2nd Syringe
Do as the pictures
Cut the tip off and enlarge the role until you can fit the flat nozzle
Take the rubber plunger off, cut a hole.
Step 6: Two Syringes Together
The two syringes will be like this
Step 7: Fill With Glass Wool and Cap It
Fill the big barrel with the glass wool
Be aware of that maybe you will have to put more or less glass wool to produce more or less foam.
Usually: more shampoo = less glass wool; less shampoo = more glass wool (You have to test the amount).
To cap one syringe on another, you have to enlarge the plastic.
Step 8: The Pump
Make a hole with the needle as the picture, it will make air mix with the shampoo+water.
Step 9: Assmebly Togheter
Step 10: Enjoy
Step 11: Tips
You can use the original tip to make foam too, you just have to fill with glass wool and use with the pressure pump.
https://www.youtube.com/watch?v=VbdwFGqB9O8
F110-015
https://www.youtube.com/watch?v=zg8N50Dbme4
F110-02
https://www.youtube.com/watch?v=MepXGA6vJ1U
F110-03
https://www.youtube.com/watch?v=s2se8axH3C4
F110-04
https://www.youtube.com/watch?v=j5mrqnYVw-s
F110-05
