Introduction: DIY Space Mouse for Fusion 360 Using Magnets
This project originated from my curiosity about CAD input devices. I realized that I was struggling to remember navigation combos in Fusion 360 whenever I switched workstations. Having never used a Space mouse before, I decided to explore the possibility of creating a similar device using only the parts I already had on hand.
To make the 3-axis joystick, I used a low-resolution magnetometer and neodymium magnets mounted on a spring system directly inspired form the real 3D connexion Space Mouse. Currently, the device emulates the mouse and keyboard to execute the orbit and pan functions within Fusion 360. There are also two shortcut buttons — one for the home view and another for fitting to the screen.
To address the lack of a native option to assign a keyboard shortcut for views in Fusion 360, we will go over a workaround that involves a custom python add-in.
Parts
- 1 × QT Py RP2040 Adafruit
- 1 × TLV493D Triple-Axis Magnetometer Adafruit
- 1 × STEMMA QT / Qwiic JST SH 4-pin Cable - 100mm Long Adafruit
- 2 × Tactile Button switch (6mm) Adafruit
- 3 × Adafruit LED Sequins - Emerald Green (optional) Adafruit
- 4 × Rubber Bumper Feet Adafruit
Hardware
- Round Magnets Amazon
- 6 × (6 × 2mm)
- Springs Amazon
- 3 × Compression 23/64" × 1-3/8"
- 3 × Extension 13/64" × 13/16"
- M2.5 Heat-Set Inserts McMasterCarr
- 24 × 3.4 mm
- M2.5 Socket Head Screws Amazon
- 10 × 3mm
- 3 × 5mm
- 7 × 8mm
- 4 × 12mm
3D printing
Finishing (optional)
- Assorted Grits Sandpaper Amazon
- Glazing and Spot Putty Amazon
- Filler Primer Amazon
- Spray Paint Amazon
- Flat Matte Clear Coat Amazon
Tools
- 3D Printer Amazon
- Soldering Station/Iron. Amazon
- Helping hands Amazon
- Precision Screwdriver Set Amazon
- Wire stripper Amazon
- Sanding block
- Flux, Solder
- Hook up wire
- Flush cutters
- Hobby knife
- Tweezers and pliers
Affiliate links may be included in the parts list. I may receive a small commission at no additional cost to you.
Step 1: Watch the Build Video
The video will give you an overview of the design and build process.
Step 2: 3D Printing
You can grab the included STLs in the page or from Github
⚠️ Few things to keep in mind before printing
- I have designed the holes and fit of the pieces to accommodate tolerances from my 3D printing setup. You might want to verify the heated inserts holes and the fit, particularly between the Base_top.stl and the Base_bottom.stl before proceeding.
- For the Base_bottom.stl, I printed it using a 5% grid infill with 3-4 wall counts. Around layer 64, I paused the print to pack in the steel BB's and add some weight. This step is essential to counteract the tension from the springs prevent the the device from sliding around.
- I suggest to go for 100% infill solid parts from the knob and the three stem parts.
- I included 1 model for the buttons but you obviously need to print it twice.
Space Mouse _1
Step 3: Finishing (optional)
If you are not familiar with post-processing techniques for FDM prints, I have some instructions in this project to guide you.
Step 4: Heated Inserts
Once the clear coat has had ample time to dry, I proceeded to install the heated inserts into the designated 24 holes.
Although it may seem excessive for most cases, I prefer incorporating them into my 3D prints. I would rather do this then deal with stripped threads after few adjustments.
Step 5: Assembly _1
Following that, I proceeded to install six mini round magnets (6x2mm) into the designated slot on Stem_top.stl.
Please note that depending on the tolerances of your 3D printer and the magnet manufacturer, you may need to apply some glue to secure them in place. In my case, I was able friction fit them.
Step 6: Assembly _2
Now, we can assemble the spring mechanism and attach it to the knob from the inside.
Begin by inserting the 3 compression springs into the appropriate holes on both Stem_top.stl and Stem_middle.stl. With both pieces compressed together, securely hold them in place while fastening the extension springs to the three sides using 6 x 3mm M2.5 socket head screws.
Once this step is complete, you can insert the entire contraption inside the knob and secure it from the inside using 3 x 5mm M2.5 screws. The Stem_middle.stl features three larger holes, allowing you to pass through the springs and screw in the entire thing to the knob from inside.
Step 7: Wiring _1
I did not plan on this initially. However, it seemed to be a great opportunity to incorporate some LEDs for added visual interest.
I carefully glued and wired 3 Adafruit LED Sequins onto the sides of Stem_bottom.stl. I took care to ensure that they did not interfere with the four screws or the lip protruding from Base_bottom.stl, allowing for proper clearance.
Next, I plugged the Magnetometer and secured over it Stem_bottom.stl to the inside of the knob using 4 x 8mm M2.5 screws.
⚠️ Check the wiring diagram
Step 8: Wiring _2
I soldered wires to both switches and carefully measured the length of the shared wire (ground) that needs to fit into the channel around the opening in the middle. Then, I placed the two printed buttons with the thicker part facing up into the slots, followed by the switch it self. Once that was completed, I positioned the Base_middle_plate.stl and guided the remaining 5 wires (3 from the buttons and 2 from the leds) through the opening from inside. Finally, I secured plate using four 4 x 3mm M2.5 screws.
Step 9: Wiring _3
Now, we can complete the wiring by soldering the remaining five wires to the RP2040 on the bottom side, ensuring they are placed as far away from the edges as possible (please refer to the image). After soldering the wires, we can neatly tuck the slack into the opening below, aligning the RP2040 snugly in its designated slot.
Step 10: Assembly _3
The assembly was finalized by positioning the Base_bottom.stl and securely attaching it to the stem using 3 x 8mm M2.5 screws then to the rest of the body using 4 x 12mm M2.5 screws.
To enhance stability, I affixed 4 rubber feet to the bottom.
Now, we can proceed to upload the code and conduct a test run of the device.
Step 11: Code _1
First thing is to get the Adafruit QT Py RP2040 working in the Arduino IDE. You can follow this guide if you never done this before.
Once the board is working properly you can open the Arduino sketch located here and install the required libraries in your environment.
#include <TinyUSB_Mouse_and_Keyboard.h>
#include <OneButton.h>
#include <Tlv493d.h>
#include <SimpleKalmanFilter.h>
In order for the sketch to compile you will also need to change the USB stack to from Arduino to TinyUSB. You can read more on how to do that here.
Once the board flashed successfully you can unplug, open the serial console and plug it back in.
By default the code prints out to the console x,y,z after initialization.
You can test the knob to see if it moves the mouse cursor and if it's in the right orientation. Incase it's reversed you can invert the values in the code if you don't want to open it and flip the sensor.
Depending on how centred the knob in your build and how the everything fits together, you might need to adjust the magRange and sensitivity values. You can move the knob to the extremities take a look at the x and y values printed on serial console and adjust the ceiling value for magRange.
The "dead zone" or center position is represented by xyThreshold you can adjust this for tighter tolerances to your preference.
int calSamples = 300;
int sensivity = 8;
int magRange = 3;
int outRange = 127; // Max allowed in HID report
float xyThreshold = 0.4; // Center threshold
The shortcut buttons are sent from these 2 functions. You can define new combos if you like using this reference.
// go to home view in Fusion 360 by pressing (CMD + SHIFT + H) shortcut assigned to the custom Add-in command
void goHome()
Keyboard.press(KEY_LEFT_GUI);
Keyboard.press(KEY_LEFT_SHIFT);
Keyboard.write('h');
delay(10);
Keyboard.releaseAll();
Serial.println("pressed home");
// fit to view by pressing the middle mouse button twice
void fitToScreen()
Mouse.press(MOUSE_MIDDLE);
Mouse.release(MOUSE_MIDDLE);
Serial.println("pressed fit");
Step 12: Code _2
To get homeview shortcut working you'll need to install the custom Add-in for Fusion.
- In the toolbar, go to UTILITIES > Scripts and Add-Ins.
- Click on the Add-Ins tab. Under My Add-Ins click on the green plus sign and copy the Send home folder located here to that location and click open.
- Make sure Run on Startup is active and click Run.
- You should see a new command > Send To Home View appear under Add-Ins.
- Click on the 3 dots icon > Change Keyboard Shortcut...
- Assign the same keyboard shortcut sent by the button press from the device: cmd+shift+h
Step 13: Done
Thank you for sticking around until the end!
This was a lot of fun to make and I enjoyed the process. There is certainly a lot of improvements to be made. I'd love to hear your suggestions in the comments below.
I have a lot of ideas and I plan on making more projects like these Follow me for more
