Introduction: DIY Spring Flower Vases
About: I'm Mary @ The Handcrafted Haven, bringing you Home DIY tutorials. Most of my tutorials are simple builds and upcycle projects.However, I have plenty of room renovations involving all sorts of DIY projects!
Here’s a quick and easy home decor DIY project to add a little spring to your home! I’m normally not a big fan of seasonal decor (unless it’s for Christmas!). However, after a long Wisconsin winter, I felt the need to make something to hold fresh spring flowers.
Materials Needed:
1″ x 4″ x 6′ pine board
Paint or stain (I used Rust-Oleum Ultra Matte Interior Chalked Paint – Linen White)
Finish Screws
Small glass vases or jars
Twine
Super glue
Tools Needed:
Paintbrush, drill and miter saw
Step 1:
Use a miter saw to cut a 1″ x 4″ x 6′ board into 4 pieces, two 15 1/4″ long and two 14 1/2″ long.
Step 2:
Paint or stain the boards. I chose to paint them using Rust-Oleum White Chalked Paint.
Step 3:
Drill 3 1/4″ holes in the top of one of the longer boards. Space the holes evenly apart. Determine the space between the holes depending on the size of your glass vases/jars.
Step 4:
Using finish screws, screw the boards together so that they form a square. Ensure that the longer boards are on the top and bottom of the square.
Step 5:
Wrap the twine around the neck of the glass jars or vases, ensuring that you glue it down with super glue as you go and leave an ample amount of twine on each end. Do this for all three jars/vases.
Step 6:
Thread the twine through the holes in the top of the wood square and tie the twine together. Cut off any excess twine. Hang each of the jars/vases from the top wood board.
And there you have it! It’s simple and it’s customizable. You can make it smaller or larger. You can use different paint or stain. You can use different jars of vases. You can of course change out the flowers you put in it.
Interested in other simple and inexpensive DIY home decor? Check out this $5 Blanket Ladder or this Farmhouse Style Bench
