Introduction: DIY Standing Desk
This Desk Moves !!!
I am a fan of exposed plywood, so i decided that my next project should be made from 1 sheet of plywood, and have an exposed plywood look
I wanted the desk to be as strong as it can be to hold my ultra wide 29" monitor and whatever i throw on.
I chose plywood, since it will be easy for you to make, with accessible tools, unlike having to go throught jointers, planners... you can have the plywood sheet cut at most lumber yard on the CNC. just take the cutlist with you when getting the plywood sheet.
Build Video:
Free Fusion 360 3D model:
Supplies:
- 1 sheet of plywood
- 2 linear actuators with 40 cm stroke, Link : https://www.banggood.com/custlink/KG3mBKeera , But checkout this version , it has a remote control and relays : https://s.click.aliexpress.com/e/_d9dJ0dp
- glue
- Brad nails
- 4 dowels
- varnish
- laquer
total cost around 155$
Step 1: Start Cutting
Part : LengthxWidth (Quantity)
fixedlegs-out 60 cmx14 cm (4)
fixedlegs-between 60 cmx3 cm (8)
fixedlegs-foot 60 cmx10 cm (4)
fixedlegs-foot-between 23 cmx10 cm (16)
movinglegs-inside 68 cmx7.8 cm (4)
movinglegs-between 26.1 cmx8 cm (8)
movinglegs-upsupport 60 cmx8 cm (4)
top 120 cmx60 cm (1)
support-bw-legs 92.8 cmx20 cm (1)
support-top 96.4 cmx6 cm (1)
Step 2: Glue Up
I used brad nails so the plywood parts stay flush to each other during glue up, you can use salt in case you dont have access to a brad nailer, the salt will help the glued parts to grip while you clamp them.
Step 3: Dry Fit and Test Sliding Mechanism
Step 4: Mount the Linear Actuators
Step 5: Connect the Leg Stretcher
Step 6: Mounting the Top
so in our design we will take that into consideration and build around this limitation by joining the top to the legs, in a way that it allows the top to move freely when the legs are not in sync (while moving) and still be strong.
for this we will make a 6 cm dado in the legs and attach a 6 cm plywood to the bottom of the top. since the force will be going down from the table top to the legs, this will help us to make a strong joint.
Step 7: Sanding and Finishing
Step 8: Q&A
I made this short video to answer some of the viewers comments
