Introduction: DIY Studded Trench Coat
About: My name is Amanda Holstein and I am a fashion blogger from San Francisco. I love sharing fashion and beauty tips, including totally doable DIY projects and how-tos on my blog! Check it out and follow it if you…
Add some edge to your classic trench coat by adding studs!
See the full post on my blog: http://advicefromatwentysomething.com/2012/07/02/diy-studded-trench/
Step 1: Supplies
What you'll need:
- Cone spikes with screws
- Pyramid studs in 2 sizes
- Dart awl
- Multi-hole punch
- Needle nose pliers
- Flat head screwdriver
Step 2: Attach Pyramid Studs
- Create indents with the stud to mark where you want the stud to go.
- Use the dart awl to poke holes through the indents.
- Insert the stud through the holes.
- Secure with the flat head screwdriver.
Step 3: Attach Cone Spikes
- Poke a hole for the cone spike with the multi-hole punch.
- Insert the screw and secure the cone spike onto it.
- Tighten with the flat head screwdriver.
Step 4: Create a Pattern and Finish
Finish attaching the studs in whatever pattern you'd like.
