Introduction: DIY Sun Tracker Robot Using Arduino
This is a tutorial for the sun tracker of this video, leave a follow! let's begin.
Step 1: Components!
For this you will be needing:
- 1x Arduino Nano
- 2x Servo Motors
- 4x Photoresistors
- 4x identical resistors of the same resistance, preferably 200Ω to 1kΩ
Step 2: Structure
For the light detection we are using four resistors that are affected by photons, these are called photoresistors. We're separating them by four walls. Everytime light hits from a certain corner the tracker will spin towards that light to have it centered between sections, dig two holes for each photoresistor and connect it to the circuit above (for the X-Axis and Y-Axis movement i glued a servo motor on top of the other).
Step 3: Code
I have attached my X-axis servo motor to digital pin 8 while Y-Axis to digital pin 7. You can copy this code, load it to the arduino and let the magic happen.
