Introduction: DIY Swimming Pool Pole Handle
My store-bought pool pole constructed from aluminum and plastic broke. It wasn't cheap and I didn't want to buy another one and risk breaking it again. So I made a sturdier pool pole using inexpensive materials.
Video
There is an embedded video at the end of this instructable.
Hardware
- 1.5" wood screws x9
Lumber
- 1x4x15.75" dimensional lumber
- 2x2x37" dimensional lumber. Use a longer length if you want a longer pool pole
Tools
- Wood saw
- Drill
- Drill bit for drilling screw holes
- Screw bit for driving screws
Step 1: Make the Pool Tool Attachment Piece
- Cross cut the 1x4x15.75" dimensional lumber into 5.25" lengths with a wood saw. You should end up with three pieces.
- Take one 5.25" piece from the previous step and rip cut it into two 1.25" wide pieces. This width needs to match your pool tools for a snug fit, mine were 1.25".
- Butt join the pieces together so that the square hole that it forms inside is 1.25"x1.25".
- Screw the pieces together.
Step 2: Make the Pole Handle
- Take the 2x2x37" dimensional lumber and cut a tenon that is 1.25"x1.25" square so that it fits into the square hole of the pool tool attachment piece. Cut the tenon 3" long.
Step 3: Assemble Pool Tool Attachment Piece and Pole Handle
- Insert the pole handle's tenon into the square hole of the pool tool attachment piece.
- Drive a screw through the pool tool attachment piece and the pole handle's tenon to keep them together.
Step 4: Conclusion
This is what the finished product looks like in my case. Yours might be different depending on whether different dimensions are used.
Potential Improvements
- Longer pole handle for convenience (and make it "telescoping")
- Use a more water resistant wood than pine
