Introduction: DIY Sword With Hand Guard
Quite a handful of people in my makerspace class made swords, so I decided to try it put on my own.
Soft foam
Cardboard
32 in. bamboo skewer
Box cutter
Hot glue
Pencil
Step 1: Cutting the Cardboard
Cut your cardboard with a box cutter so its dimensions are 12 in. by 4 in.
Step 2: Bending the Cardboard
Bend the cardboard so it looks like a semi circle. Make sure the ends are aligned. It'll crease while bending it.
Step 3: Drawing Dots on the Cardboard
From 2 1/2 in. from one end, draw a dot from the center of the edge. Do the same on the other side.
Step 4: Stabbing the Cardboard
Poke holes where the dots are using a pencil, then the bamboo skewer and align the two holes together. Stab both holes with the bamboo skewer.
Step 5: Cutting the Styrofoam
Take out the bamboo skewer from the cardboard then cut your soft styrofoam to 3 ¼ x 2 ¼ x 1 ½ inches. Stab the styrofoam towards the edge of it. Take out the styrofoam from the skewer.
Step 6: Stabbing Both the Cardboard and Styrofoam
- Take the cardboard and put one edge through the skewer. Put the styrofoam through the skewer, then the other edge of the cardboard.
Step 7: Hot Glueing Everything
Hot glue the holes from the skewer. This includes the styrofoam as well.
Step 8: The Final Step
Make any fine adjustments if needed.
