Introduction: DIY Synth Wood Case
This is plans to make your own DIY Synth Wood Case.
Enjoy and Customise it like you want.
Step 1: First Wood Cut
You need to cut a first plank of wood to make this first part.
I used a 15mm wood plank.
(the holes are not required, it's up to you with your sound installation)
Step 2: Second Wood Cut
In a second time, you need to cut an other plank of wood, to make this piece. This is for the upper part of the DIY analog Synth
I used the same 15 mm plank
(also, holes are not required to make wath you want with this part)
Step 3: Third Wood Cut
The third and last cut step is for cut the 2 lateral parts.
Step 4: Assembling and Plans
For finishing, assemble the 4 pieces as in the drawing.
You must use a screwdriver and wood screws.
You can see sizes in picture, and download the sketchup plans if you want.
