Introduction: DIY- Transformable Shelf
Here, we are going to create seveal units and later connect them to the way you want it to form and place.
Step 1: Choose Material
Here are the materials needed:
Applied wood
Cutting machine specifically for wood
Holding clamp
Glue gun
Sand paper
Rubber cement
Ruler
Pen
Applied wood
Holding clamp
Glue gun
Sand paper
Rubber cement
Ruler
Pen
Step 2: Start Cutting and Pasting
Now use cutting machine to cut the applied wood in measurement.
For example...
one unit: two pieces in 3"x 2" and one in 3"x 5"
another unit: two pieces in 3"x 4" and one in 3"x 5"
etc.
It is all depends on how you want it to be!!
For example...
etc.
Step 3: Clean Up
After pasting them together, measure the area you want to cut off and use the machine to take the parts out. Basically, I am cutting a line strip out of the applied wood.
Here are the samples of how it look like.
Step 4: Clean Up
Later use sand paper to clean the edges and apply rubber cement onto the edges to prevent it from hurting.
Step 5: Final Composition
From all these units, you can now form it to whatever way you want. You can pile it up like a shelf or simply make them to be dividers.
