Introduction: DIY Tutorial - How to Make a Textured Ring With Sterling Silver!??
Tools and Materials:
- Sterling silver
- Tableting machine
- Marker Pen
- water
- hammer
- Hammer Texture
- Scissors
- Lighter
Step 1: Design
Draw up the outlines of your ring-design on the surface of the silver with a marker. Confirm the length of the ring.
Step 2: Cutting
Trim out the silver you need according to the outlines with scissors.
Step 3: Hammering
For the silver piece is already bended after being trimmed off, we use a hammer to hammer it to make it straight and plane.
Step 4: Heating
Heat up the silver to soften it.
Step 5: Cool Down
Cool the silver down with cold water. Be careful about the heat.
Step 6: Flattened
We use a press-machine to press and lengthen the silver for it has become softened after heating.
Step 7: Manufacturing Texture
The squashed and lengthened silver will be hammered by a texture-hammer to make textures and decorative pattern.
Step 8: Trim
After pressing, the length of the silver will be different. So we will mark the size of the ring again on the surface of the silver.
Step 9: Cutting
Trim the silver according to the marking.
Step 10: Polished
Polish the trimmed silver to make the incision become smooth.
Step 11: Shaping
Put the silver onto the model of the ring. Bend it with strength and make it into a ring with a opening. Hammer it to make it fixed and firm.
Step 12: Cutting&Hammering&Polished
Pick another smaller silver piece and process the same procedures as above. This piece will be kept for the next step.
Step 13: Combination
Place the small silver piece above the opening ring and bend it, hammer it slightly as the image shows to fit these two parts completely.
Step 14: Add Solder Powder
Fix the ring on the table and add welding powder to the area which needs to be welded. Place the small silver piece above.
Step 15: Welding
Heat the welding part of the two parts to make them welded together completely.
Step 16: Cool Down
Cool it down with cold water.
Step 17: Shaping
Put the successfully welded ring back to the ring-model and hammer it slightly to fix the shape of it.
Step 18: Placed in the Deoxidized Solution
Place the ring into the de-oxidation solution for a few minutes.
Step 19: Cleaning
Slightly brush away the dirt on the ring’s surface.
Step 20: Complete!!
About this ring, we creatively use the advantage of the silver elements, which is easy to be shaped and be textured, to combine the both sides of the ring. This craft will make the ring less heavy and easier to be shaped and fixed, which makes the ring more charming and smarter.
It's a DIY Tutorial for Making a Textured Ring with Sterling Silver! Hope you will like it!
Follow us on Instagram or Facebook, you can know more details about us!
Facebook: HappyJewelrySupplies
Instagram: HappyJewelrySupplies
Our Website: www.happyjewelrysupplies.com
