Introduction: DIY USB 25-keys MIDI Sensor Keyboard Using Bluepill (STM32F103)
I'm was always interesting to try playing the piano, but real MIDI keyboard too expensive... at least for 5-min playing (and never play again, of course) :D :D
So this is reason why I decided to build MIDI keyboard by itself.
Unfortunately, I don't have even toy MIDI keyboard for upgrading it to normal keyboard. But build by itself mechanical keyboard is really hard....
And I decided to build sensor variant of keyboard.
Idea is really simple - just took any tin/foil, cut from that keys with form same as piano keys, fix it to a random board.... and that's all, ready to use!
From electrical side all simple too. Just connect piece of foil/tin to microcontroller. And that's all, lol.
How this works? 🤔
All piano keys is a capacitive touch sensors.
The microcontroller continuously measure needed time for change pin state from 0 to 1 and and back.
That's have little lag, because any gpio pin have parasitic capacitance.
And when finger touches pin there is a current leak happens and time to charge/discharge changes.
The algorithm is simple:
- Change pin to input with internal pull-up
- Measure time until pin have 1 state
- Change pin to output=1 for complete charge parasitic capacitor
- Change pin to input with internal pull-down
- Measure time until pin have 0 state
- Change pin to output=0 for complete discharge parasitic capacitor
Any deviations in these measured times is meaning for key press. :)
Project on github: https://github.com/Azq2/stm32-sensor-midi-keyboard
- Tin or foil.
- Any wooden or plastic board.
- STM32F103 (bluepill).
- Some count of wires.
- Nail polish (stolen from your gf or mom, that's important).
- Basic skills in Linux (for build and flash firmware).
- Really sorry, but I don't use Arduino :D
Step 1: Cut Keys From Tin or Foil
I'm too lazy for manual drawing all blueprints then I written PHP script which drew this instead of me.
You can found this script in my github: gen-piano.php
Usage is simple:
# php gen-piano.php <keys count> php gen-piano.php 25
This script supports any MIDI-keyboard size: 13, 25, 37, 49, 61, 76 or 88 (you can use it in own projects)
For this project I uploaded already pre-generated blueprints:
- Black keys layout for cutting: docs/piano-black-keys-for-cut.png
Tails is needed for fix keys on board and for soldering wires to keys. - White keys layout for cutting: docs/piano-white-keys-for-cut.png
Black keys bending to "П" form for comfortable pressing and for avoid misclicks. - Drill layout: docs/piano-drill-map.png
In this print all keys placed with indents and have marks for drilling.
All of these images have 300 ppi resolution. Just print and cut! :)
Step 2: Install All Keys to the Board
- Use docs/piano-drill-map.png for drilling holes.
- Place tail of keys to drilled holes for fixing it on the board.
Step 3: Solder Wires From Keys to Microcontroller
Yes, you need solder 25 wires to your bluepill. That's not enjoyable, I know :D
Current pinout which use in the code:
- PB13 (C3)
- PB14 (C3#)
- PB15 (D3)
- PB12 (D3#)
- PA8 (E3)
- PB8 (F3)
- PB9 (F3#)
- PB7 (G3)
- PB3 (G3#)
- PA1 (A3)
- PB1 (A3#)
- PA0 (B3)
- PB4 (C4)
- PB0 (C4#)
- PA7 (D4)
- PA2 (D4#)
- PA4 (E4)
- PB5 (F4)
- PB11 (F4#)
- PA5 (G4)
- PA15 (G4#)
- PA3 (A4)
- PA6 (A4#)
- PB6 (B4)
- PB10 (C5)
But you can connect keys in any random order and just generate new App::m_pins using DEBUG_SORT_KEYS=true mode.
Step 4: Lacquer All Keys
All keys must be lacquered for isolation. That important if you don't want to fried your MCU. :)
Best choice for this is regular nail polish. As an alternative you can use epoxy resin or even scotch tape.
Step 5: Build and Flash Firmware
You need any Linux-based OS. On Windows/OSX you can use Linux on Windows with WSL or install Ubuntu in VirtualBox.
1. Download ARM GCC from this link: https://developer.arm.com/downloads/-/gnu-rm
Choose gcc-arm-none-eabi-10.3-2021.10-x86_64-linux.tar.bz2 file.
And extract it to /opt
sudo tar -C /opt -xpvf ~/Downloads/gcc-arm-none-eabi-10.3-2021.10-x86_64-linux.tar.bz2
2. Add this path to your PATH variable. Just edit /home/USER/.bashrc file and add this line to the end:
export PATH="$PATH:/opt/gcc-arm-none-eabi-10.3-2021.10/bin"
After this your need to reopen Terminal.
3. Install all needed tools:
sudo apt install build-essential git
4. Clone repository and build:
# Make dir for building mkdir ~/build cd ~/build # Clone project from repository git clone https://github.com/Azq2/stm32-sensor-midi-keyboard git submodule init git submodule update # And build cd stm32-sensor-midi-keyboard ./build_libopencm3.sh make
5. After this you have app.bin and app.elf. Just flash one of this in any appropriate way.
In case of BlackMagic Probe you can simply flash using this command:
make install
Also, you can use prebuild firmware: https://github.com/Azq2/stm32-sensor-midi-keyboard/releases
Step 6: Configuration
Okay you built this device. And as expected, nothing works. Oh no, this is scam???? 😱
No, that's okay. Different constructions have different parameters and my settings maybe not suitable for you.
Mainly, you need tune these parameters for your device:
- SENSOR_WHITE_KEY_THRESHOLD - Threshold for white key, at which deviation (in %) will mean key is pressed.
Default value is 1000.This value in percentages multiplied to 100.
100000=100% - SENSOR_BLACK_KEY_THRESHOLD - Threshold for black key, at which deviation (in %) will mean key is pressed.
This value in percentages multiplied to 100. 100000=100%
Other parameters:
- NOTE_OFFSET - MIDI note for first key: 36 - C2, 48 - C3 (default: 48)
See for more info: https://studiocode.dev/resources/midi-middle-c/ - KEY_VELOCITY - Velocity of key press (default: 64)
- DEBOUNCE_CYCLES - Time for debounce. Value in the cpu cycles. This value used to reduce jittering keys state. (default: 1000000)
- CALIBRATION_CYCLES - Cycles for measure average capacitance for initial state. (default: 100)
- SAMPLES_CNT - Cycles for averaging measured capacitance (default: 8)
- DEBUG_SORT_KEYS - Debug mode for generatin new App::m_pins in right order (default: false)
- DEBUG_PRESS_KEYS - Debug mode for tune thresholds (default: true)
You can find all of these parameters in src/App.h
Step 7: Fixing Order of Keys (optional)
This needed if you soldered wires in random order instead of using from instruction.
- Set DEBUG_SORT_KEYS=true and connect by USART
- Press all keys in right order, from left to right
- Copy content of structure which printed to USART
- Replace content of structure App::m_pins in file: src/App.cpp
I use USART1 for debug output. Connect any USART-to-USB adapter to these pins:
- PA9 (TX) to adapter RX
- PA10 (RX) to adapter TX
Step 8: Tune Sensitivity (optinal)
This needed if default settings not unsuitable for you.
- Set DEBUG_PRESS_KEYS=true and connect by USART
- Press on any key and see debug output.
- Just change SENSOR_BLACK_KEY_THRESHOLD and SENSOR_WHITE_KEY_THRESHOLD until key normal works.
- If keys jittering, then increase DEBOUNCE_CYCLES (If slower reaction, then decrease).
Step 9: How to Use With PC?
Just connect and it works. I use standard USB MIDI protocol.
Step 10: All Done. Just Enjoy!
Also I recorded this demo for proof of work.
P.S. I can't play on piano, I tried to play random melody before the first difficult part :D
