Introduction: DIY Universal HEPA Filter Prototype Made With Open Source 3D Printed Parts
I’m going to show you my version of a custom HEPA filter made using a standard HEPA vacuum cleaner filter and some 3d printed parts that you can find on thingiverse using the link: https://www.thingiverse.com/thing:4247922
FIRST OF ALL: THIS FILTER IS A PROTOTYPE AND HAS NOT BEEN TESTED OR APPROVED BY ANY FIELD SPECIALIST SO USE IT AT YOUR OWN RISK
This filter can also be used on different 3d printed masks as long as they have a round hole with a diameter of 40mm.
The filter model I am using is an Electrolux vacuum filter model ef75b (part with grey plastic material). Some vague information on the internet suggests that this filter is classified as hepa10 or 11 which would mean it has a filtering efficiency between 80 and 95% of particles bigger than 0.3 microns. (I would recommend at least HEPA 13 for a good protection based on what is commonly found on the market and what Wikipedia says about HEPA filter class)
IMPORTANT:NOT ALL HEPA FILTERS HAVE 99.9% EFFICIENCY YOU CAN FIND MORE INFORMATION ON WIKIPEDIA: https://en.wikipedia.org/wiki/HEPA
The best part about this prototype is that you can use a HEPA filter cut out from different filter models with a higher class, as long as the folds are 13mm or smaller.
3D Printer
HEPA material from a HEPA filter
Cyanoacrylate / SuperGlue / Polyurethane Resin
Step 1: Printing and Preparation of the Filter
Download files from https://www.thingiverse.com/thing:4247922 and print the main part (there are two different models ).
After i printed the main filter parts, i cut out the hepa filter to the desired length.
If you are using the HEPA material from a square model filter you should also check what is the right number of folds you need to cover the whole radius of the circle and stick the first and last fold of the filter in such a way that there is no air gap. SuperGlue should work to stick the folds together.
Step 2: Sealing Filter in Place
After that i used cyanoacrylate to seal the filter in place. the cyanoacrylate known also as superglue is very toxic if the vapors are inhaled so the filter has to be made in a ventilated area and left for a few hours to set.
You can also use polyurethane resin which would be a better alternative and it sets in about 5 minutes
Step 3: Finished
I made a few other parts for attaching it to a mask, connecting two filters together and sealing the end of the filter. you will find all the parts on thingiverse.
