Introduction: DIY V-Day Inverted Fishtail Bracelet
This DIY Valentine's Day Inverted Fishtail Rainbow Loom Bracelet with a loom!
It is very fun and simple to do, so let's begin.
Step 1: What You Need
These are the supplies you need:
-Rainbow Loom Rubber Bands (Pink, Red and Purple)
-A Rainbow Loom ( I am using Fun Loom)
-Loom Hook (or a crochet hook)
-C Clip (or S Clip)
-C Clip (or S Clip)
Step 2: Starting Your Bracelet
To start your bracelet, start by placing your first band, (I am using pink) like a figure eight on two pegs.
Then just simply place two rubber bands over it. (The order of rubber band colors is: Pink, Purple and then Red.)
Then to loop the bands, pull back the purple band with your hook and grab the pink rubber band and pull it up and off that peg and do the same thing on the other side of the pink band. Click the squares on the pictures for tips.
Step 3: Looping More Rubber Bands
Once you have looped the pink band off in step 2, now its time to place a pink rubber band on top.
Go in and pull back the red band, and grab the purple band and loop it off like in step 2.
Here's how to loop it off again: Pull back the red and grab the purple band with your hook. Then pull it up and around off the peg. Then just repeat on the other side of your purple band. Then repeat this process alternating colors until your bracelet is the length you want.
Step 4: Finishing
Once you made the bracelet long enough for your wrist, it's time to clip it all together.
Take your bracelet off the loom and transfer you bracelet to your fingers just like your fingers are the pegs. Simply add a C-Clip and get the other end to clip both ends together. Ta-Da! Your done! Enjoy wearing your new bracelet!
