Introduction: DIY Variable Power Supply
DIY lab bench power supply made with LM317.
Easy to bulit.
Safe no transformer.No HIGH VOLTAGE.
Step 1: Gather Every Coponents
Components:
Resistors:
3.3k R1
240 ohms
5k Potentiometer
Capacitors:
3300uF,50v C1
1uF,63v
10uF,63v
Binding Post
DC jack
12v 1A Adapter.
Heat sink
A plastic case
Perf Board
Step 2: Placing the Components in Pref Board
Place the capacitor , resistor and LM317.
And solder all the components.
Step 3: Assembling Everything in Case
Assembly everything in the case.
Mark lines on the front of the case for holes.
Drill holes for the the Binding post, potentiometer,DC jack.
And screw the the Binding post, potentiometer,DC jack.
2 Comments
5 years ago
Do you use any kind of volt meter to track the output as you are using it?
Reply 5 years ago
I am using a multimeter to track the output voltage.
Check my channel Great Spike in YouTube.
