Introduction: DIY WINDOWSILL PET
This is a fun little way to incorporate gardening to the inside of your home, while also making it as cute as possible too!
Step 1: Gather the Materials...
To make a Windowsill Pet plant, you will need the following
♥ A plastic bottle of any kind
♥ Cardboard, newspaper or anything to protect your work space
♥ Decorating materials such as paint or colored markers
♥ Decorating utensils such as paint brushes
♥ Scissors
♥ A lighter (optional)
♥ A plant
♥ Soil
Step 2: Choose Your Pet... ♥
Now its time to decide on the animal that you want to make. This can be literally anything, from a bunny to a giraffe!
Then draw its outline onto the bottle as seen above, and cut it out.
♥ OPTIONAL ♥
To get rid of the sharp edges that the plastic can create, run a lighter around the rim. Be sure to avoid any ears as the plastic will bend out of shape... and you will end up with wonky ears!
Step 3: It's DECORATING Time!
Now you can decorate your pet! I used paint to cover the entire pot. I found that one coat of paint just didn't suffice, so I recommend 3+ coats to get an even coverage.
After the base of the animal is done, you can add the fine details. I added the face with textas.
Step 4: Plant Time...
Once the decorating is finished, you can add the plant!
Firstly, pierce a few small holes at the bottom so that water can get out of the pot.
Then fill it up with soil and add your chosen plant. (I chose a succulent because they don't need a lot of care and therefore have a better chance of surviving in my care ‾ ‿ ⁀ )
Step 5: ♥ Enjoy Your New Pet Plant ♥
And you are finished! This is a fun little way add dynamics to a room and is also fun to make!
If you enjoyed this Instructable, and find it worthy... don't forget to vote for it
xoxo - Madie
P.S. Don't forget to check out my YouTube Chanel for a video tutorial!
