Introduction: DIY Wide Beaded Bangle
This is an easy and fun bracelet to make. Only beads and threads are needed and the cost is quite low. Keep reading and try your own!
Step 1: Materials You’ll Need:
Step 2: Attach the Threads Onto Clasp
Prepare two strands 1mm Nylon Thread of each color, one about 80cm for the working ends and one 40cm for central holding ends. In the diy bangles, you may need totally 10 strings like that;
Next, pass the two same color strands through one hole on your clasp by utilizing section of remaining Tiger tail wire; Pull the threads and fix them by tying one square knot. Keep the thread tips stay symmetrical. Do same for the next four colors.
Step 3: Add on Beads
Each time once finished a complete Square Knot thread one 8mm Acrylic Bead onto the holding ends. One strand may require 15 groups of the knot and bead.
In accordance to the above processes, finish the rest four strands. Please just freely arrange and assemble the beads with threads depending on your preference.
Step 4: Finish the Beaded Bangle
Bring the holding ends through the holes on other portion of the clasp as what we done at beginning. Tie a fasten knot to anchor the threads.
Finally, trim all excess threads and lightly melt the ending parts with lighter.
6 years ago
nice
