Introduction: DIY Wireless Door Sensor Using ESP8266 + NRF24L01 || Home Automation Security System ||
Looking for a simple yet effective home security solution? This DIY Wireless Door Sensor project enables you to monitor doors remotely and receive alerts whenever they open or close. The project uses an ESP8266 microcontroller and an NRF24L01 wireless module to transmit data, offering a cost-effective and reliable home security solution.
In this tutorial, you will learn how to set up the circuit, required components, and the code to build this smart home automation project.
Features
✅ Wireless communication using NRF24L01
✅ Low-power ESP8266 module for IoT applications
✅ Alerts via buzzer and LED indicators
✅ Expandable to multiple doors
✅ Ideal for DIY home automation and security
Components Required
- ESP8266
- NRF24L01
- Magnetic Door Sensor
- Buzzer
- LED
- Resistors
- Jumper Wires
- 12V Power Adapter
You can get all the components from JLCMC.
Step 1: 1️⃣ Interfacing NRF24L01 With ESP8266 (Door Sensor Unit)
The NRF24L01 is a wireless communication module used to transmit the door sensor data to Hub.
Connections:
- CE - D2( GPIO4)
- CSN - D1(GPIO5)
- SCK - D6(GPIO12)
- MOSI - D7(GPIO13)
- MISO - D8(GPIO15)
Step 2: 2️⃣ Interfacing LED With ESP8266
The LED is used as a status indicator for the door sensor.
Connections:
- Led - D0(GPIO16)
Step 3: 3️⃣ Interfacing Button With ESP8266
A push button is used to reset(boot) or restart the ESP8266. When pressed, it connects GPIO2 (D4) to GND, triggering a reset.
Connections:
- Button - D4(GPIO2)
Step 4: 4️⃣ Interfacing Door Sensor With ESP8266 🚪🔍
The magnetic door sensor detects whether the door is open or closed by sending a signal to the ESP8266.
Connections:
- Door Sensor - A0(GPIO ADC0)
Step 5: 5️⃣ Interfacing DC Power Jack
For powering the ESP8266, a DC Jack (7v - 12V ) can be used with a Voltage Regulator.
The circuit consists of:
Transmitter (Door Sensor Unit): ESP8266 reads the door sensor status and sends data wirelessly via NRF24L01.
Receiver (Base Station): Arduino Uno receives data, controls an LED and buzzer, for real-time monitoring.
Receiver (Arduino Uno) - Base Station
NRF24L01Arduino UNO
- VCC - 3.3V
- GND - GND
- CE - D9
- CSN - D10
- SCK - D13
- MOSI - D11
- MISO - D12
- Buzzer - D7
- LED - A2
Step 6: 🔹 Code for Transmitter (ESP8266 - Door Sensor)
Step 7: 🔹 Code for Receiver (Arduino- Base Station)
Step 8: 🔹 How It Works
1️⃣ The door sensor detects when the door is opened or closed.
2️⃣ The ESP8266 transmitter reads the sensor data and sends it wirelessly via NRF24L01.
3️⃣ The Arduino UNO receiver receives the data and activates the LED and buzzer accordingly.
4️⃣ If the door is opened, the buzzer beeps as an alert.
5️⃣ You can expand this project by integrating it with a mobile app or home automation system.
Step 9: 🔹 Applications
✅ Home Security – Monitor your doors remotely.
✅ Smart Automation – Connect with IoT platforms.
✅ Warehouse Monitoring – Secure storage spaces.
✅ Access Control – Track entry and exit activity.
Step 10: 🔹 Conclusion
This DIY Wireless Door Sensor project is an affordable and effective way to enhance home security. With ESP8266 + NRF24L01, you can monitor doors and receive alerts in real time. This project can be further expanded with IoT platforms like Blynk, MQTT, or Home Assistant for remote monitoring.
Step 11:
Sponsored by JLCMC: Your Go-To Partner for Mechanical Parts!
Introducing JLCMC, the newest addition to the trusted JLC family, delivering high-quality mechanical parts at the best prices in the market. With a legacy of excellence established by JLCPCB, JLCMC is here to provide reliable and affordable solutions for all your mechanical needs.
Why Choose JLCMC?
- A Trusted Name:
- JLCMC is built on the foundation of JLC services, a global leader in PCB manufacturing and prototyping. Their commitment to quality and customer satisfaction carries forward into their mechanical parts services.
- Unbeatable Prices:
- True to the JLC legacy, JLCMC offers mechanical parts at industry-leading prices, ensuring that your projects stay on budget without compromising on quality.
- Wide Range of Products:
- From precision-engineered components to custom solutions, JLCMC has everything you need to bring your ideas to life, whether you're a hobbyist or a professional.
- Global Trust:
- JLC services have earned the trust of millions of makers worldwide. With JLCMC, you get the same reliability, now in the realm of mechanical parts.
