Introduction: DIY Wood Burnt Dirt Bike Clock
Didn’t have the right clock part and couldn’t get the clock to fit and had to wait until I found the right part and figured out where to put the numbers
-Wood burner
-Circular log or piece of wood
-Clock mechanism
-Protractor
-Ruler
-Pencil
-Sandpaper
Step 1: Sand Wood
Sand wood until smooth
Step 2: Circumference and Drill
Find middle of wood, then drill a hole in the center of wood ( hole size will vary depending on the clock mechanisms size), next find radius, then find the circumference of the circle log (C=2🥧r)
Step 3: Numbers
Place marks for numbers and draw number in your own way for your project. Each number is 30 degrees apart, use a protractor to be precise in your measurements.
Step 4: Design It!
Draw and design your picture you are going to wood burn, can be anything doesn’t have to be a dirt bike, get creative with it.
Step 5: Wood Burn It!
Wood burn your numbers in and wood burn your design, ( be careful when using wood burner it is extremely hot)
Step 6: Add Clock Parts
Put together the clock pieces and adjust to the right time, ( clock instructions will vary depending on the type of clock mechanism you buy)
