Introduction: DIY Wooden Bluetooth Speaker + FM + PowerBank
Hello Everyone,
Here I made a Wooden Bluetooth Speaker + FM and also a Power Bank. I used Scrap parts from My Old Creative Speakers and Battery from Old Laptop Battery.
Step 1: Gather the Parts
Components :
1)- Bluetooth MP3 Decoder Board
2)- PAM8403 Audio Amplifier
3)- DC - DC Converter
4)- Power Bank Module
5)- LiIon / LiPo Battery (Scrap)
6)- Speakers (Scrap)
7)- Antenna (Scrap)
8)- Wooden Pieces (For Box)
9)- Speaker Wires
Step 2: Connection
For 5V Power Supply, I use LiPo / LiIon Battery with DC-DC Converter adjusted to 5V Output.
PAM8403 Input Audio Connected to Bluetooth Decoder Board AUDIO Output.
Step 3: Making the Box
Material : Teak Wood 8mm
Dimensions : 200mm x 100mm x 70mm
I bought it from a local wood shop
Front Panel : Hold the Speaker & Wrapped by Cloth
Box : Hold the Other Components
Holes : BT Decoder Board, Power Bank Output, Charging Port, Button & Antenna and Also for Air Ventilate
Paint :
✓ Sanded with 180 grit
✓ Two Coats of Wood Primer
✓ Sanded with 220 grit
✓ Two Coats of Brown Wood Paint
I covered the Inside of Box with Thin Sheet of Sponge.
Step 4: Final Product
Use Glue Gun or DoubleSide Tape to stick the Components Inside the Box.
Troubleshoot : Check Every Connection & Power Supply if It not Working properly.
Use Capacitor of 16V 100uf Parallel to Power Supply for Constant Power Supply.
I use Glue Gun to form button for Bottom Grip.
Test It?? Enjoy It!!.
Step 5: Testing
✓ Test the Charging Port
✓ Test the PowerBank Output
✓ Test the Speaker
