Introduction: DIY Wooden Step Stool in Rainbow Colors
In this instructables I'll show you how to build a colorful rainbow step stool using simple tools and leftover wood. 🌈🪚
Whether you're a beginner in woodworking or just looking for a fun and cheerful project, this step stool is perfect for adding a pop of color to your bathroom/home — and it’s super practical too!
I’ll walk you through the entire process: cutting the wood, assembling the frame, and oiling each slat in bright rainbow colors.
✨ Tools & materials used:
- Scrap wood (oak & padouk)
- Screws & wood glue
- Rubio Monocoat Oil (rainbow colors)
- Tools: planer, saw, drill, clamps
Let me know in the comments if you’d build your own — or what colors you’d use!
Feel free to subscribe to my YouTube Channel to see more of my work!
If you liked this instructable and the video, don't forget to give me a vote in the "Rainbow" contest. Thank you!
Step 1: Making the Top Slats for the Step Stool
Because I'm using reclaimed wood/scrap wood, I had a lot of gluing to do for this step stool.
First I planed my scrapwood so I had smooth surfaces to glue them together. And then when I had the 'new' lumber, I jointed and planed that into the right width and thickness. My slats were 60cm long, 2cm thick and 5cm wide. I used 7 slats because I wanted to make it of course in the 7 colors of the rainbow!
Step 2: Making the 'legs' for the Step Stool
For the legs of the step stool I also used scrap wood which I had laying around. I used padouk for the legs because I love the beautiful red color of the wood. I glued two pieces together, because I wanted 35mm thick legs. Once they were glued together, I jointed and planed the wood again. 14cm high and 35mm thick.
I also drove in two screws on each side of the leg, so 8 screws in total for the two legs. To give the glue joint some extra strength. Then I started cutting out the shape on the bandsaw. I did this to give the bench a more elegant look, and also to take a bit of weight of. When this was done, I used a chamfer bit in the router to chamfer all the edges of the slats and the legs. For the legs I used a heavier chamfer than I used for the slats.
Step 3: First Step of Assembling
To assemble the bench I didn't want visible screws in the top. So to solve this problem, I attached a smaller beam on the bottom with some screws. I made sure to pre-drill all the holes before I was driving in some screws.
Step 4: Extra Support
I decided to give the step stool a little bit more of stability by attaching two crossbeams between the legs.
Step 5: Oiling Everything
Now that all the holes are drilled, you can remove the screws again and it's time for some finishing!
I used the oils from Rubio Monocoat, You only need to apply one coat, let it sit for 15-20 minutes and then wipe of the excess with a cloth.
For the legs I used transparant Rubio Woodcream, just apply and no wipe-of!
If you want to try out the oils yourself, you can use my discount code for 5%: "JOLIEN5": https://www.rubiomonocoat.be/nl?affiliate_code=etAE9yeMYZ&referring_service=link
Step 6: ASSEMBLE AND READY!
Now that all the pieces are finished and dry, you can assemble the step stool again!
