Introduction: DIY Beaded Earrings- Pearl and Rose Earring DIY
These DIY beaded earrings will demonstrate you an easy way regarding pearl and rose combined earring DIY. Within five minutes, you will create this beautiful pair.
Step 1: Make Beaded Flower Dangles
1st, slide 6 4mm ivory beads onto a piece of 20cm wire, and then cross ends through a 10mm pink bead;
2nd, add one 6mm ivory bead to each end of wire and cross ends through another pink bead;
3rd, continue beading and crossing;
4th, add 2 6mm ivory beads to each end and cross ends through your flower bead;
5th, slide 2 ivory beads to each end and tie 2 overhand knots to finish the dangle;
6th, tuck ends into adjoining beads, cut off excess wires and repeat to make the other.
Step 2: Attach Earring Hooks Onto Dangles
1st, use plier to open the loop of earring hook;
2nd, attach it to the top of dangle and close the loop.
Step 3: The Finished Pearl&rose Earrings Are Like This:
Till now our earring diy tutorial is completed; with these beautiful pearl beads and floral beads, you can try other ideas about DIY beaded earrings, then you will find that even the same beads can generate completely different effects.
