DIY Carbon Tape Heated Vest
Intro: DIY Carbon Tape Heated Vest
diy heated clothing kit
The pattern made from some factory vest.
6 meters of carbon heating flex tape from www.carbonheater.us and now on Amazon placed on back and both sides. By touch carbon is a little bit like a loose weave silk. It's very soft but strong enough. Because of big length it provides uniform heating of body.
STEP 1:
Back.
STEP 2:
Front.
STEP 3:
Tape connected in parallel 6x1m. It takes about 3A under 12V (36W).
STEP 4:
You can sew wire to carbon tape to make a good and flexible connection. The contact place shouldn't be hotter than the tape itself. If not you must increase the contact area. The best idea to place wire between two layers of carbon tape.
STEP 5:
Contacts may be sewed by sewing machine or just wraped with a wire.
But as you can see sewed contact is colder than the tape itself (left contact).
Wraped contact (on the right) is more hotter than tape.
STEP 6:
Carbon tape can be extended. Place two pieces of carbon tape together on each other with little overlap and sew it on. As you can see the connection place is not hotter than the tape itself.
STEP 7:
STEP 8:
I use it with an adjustable controller.
140 Comments
NWBrewer 10 years ago
Shenzhen 10 years ago
rngy 6 years ago
Can you put it in the dryer?
Shenzhen 6 years ago
Yes, of course.
rngy 6 years ago
I'm assuming on low heat or tumble dry? I'm guessing the wires can become damaged on high heat
We used silicone wires only. Depends on quality they can 300F-480F.
Yes, you can tumble dry it.
GeorgeB283 5 years ago
Shenzhen 5 years ago
You can use the most of led dimmers.
27A:
https://www.amazon.com/Dsstyle-Controller-Wireless...
4A:
https://www.amazon.com/Inline-Dimmer-Controller-Ad...
12A:
https://www.amazon.com/FAVOLCANO-Controller-Dimmer...
ChristieF6 6 years ago
1. Silicon wire run to connection points only.
2. Usualy you should use male/female connector to connect your blancket to solar panel.
3. Carbon fiber tape placed between two layers of cloth fabric and you cannot see it. You can use fabric glue or you can just sew carbon tape to fabric.
abotonak 6 years ago
Thank you very much for your immediate response!!!!
We wish you every success with your project! Make an instructable with our carbon and permanent link to our site and get 5 meters any width for free.
If I use instead, 4 pieces of 80cm x15mm connected in parallel, can you please tell me where should the conections be? If possible mark on attached drawing. Thank you in advance
It will be 40W. With that power if I were you I would heat front also.
The upper connection point has about 1,7A. For that current recommended to use silver glue or split it into two points.
or maybe 360cm x15mm connected in parallel every 60 cm?
Well, yes, it can be connected this way but 1 piece of 60 cm draws 1 A and gives 13 W so the total 6 A and 78 W. Good level for bikers and bike battery.
Hello. I am writing from Greece.! I want to make a vest as a that will be heated only on its back side (neck, shoulders and back) I am having difficulty in understanding the relation between the length of the carbon fiber and the temperature.(in specific 5 carbon stripes, each 55 cm long, connected in parallel and powered from a 5v power bank). The maximum desired output temperature is 60℃.
