Introduction: DIY Film DX Code Labels
Do you have a stuborn film camera that takes the ISO information from the DX code on the canister?
Do you want to push/pull your film, but your camera doesn't let you override the ISO value?
Did you buy cheap film with no DX encoding in the canisters?
I have the solution for you!
Some might scrape the paint to uncover the metal contacts. However, I find it very time consuming.
I prefer to make DX labels and stick them to the canisters.
More information on DX encoding:
Wikipedia
DX encoding simulator
If you find something wrong in this instructable, please tell me.
Wikipedia
Step 1: Tools and Materials Needed
To follow this instructable you will need:
- Aluminium foil
- Clear plastic adhesive sheet
- Adhesive tape
- Scisors
- X-acto knife
- Printer, to print the label layout.
- Aluminium foil
- Adhesive tape
- Scisors
- X-acto knife
Step 2: Print Layout
In this step you have to transfer the pattern onto the paper backing of the adhesive sheet.
You can use the attached pdf files to print the patterns.
I used a cardboard sheet and taped the adhesive sheet, so I could feed it through the printer.
But you can also print a regular sheet of paper and then manually trace over onto the adhesive sheet.
Then you have to:
1- Cut the label.
2- Remove the black areas with an X-acto knife.
3- Bend in half. It will make it easier for the next step.
Step 3: Assemble Labels
Now, cut a piece of foil roughly the size of the label. Don't worry with precise measurements.
Use the bend on the label to peel apart only half of the paper backing.
Then stick the foil to the exposed adhesive of the label. Make sure you match the edge of the foil with the bend you previously made.
Peel apart the remaining paper, and fold the label over the foil.
Then cut away the excess foil, following the edges of the adhesive paper.
Finally, don't forget to note the direction of the label and the ISO value with a permanent marker. I usually use the barcode side as a reference.
Step 4: Use It
Now you just have to stick the label to your film canister. Use two small pieces of tape on each side of the label.
Do not cover the exposed foil!
To verify if the contacts are touching correctly the label, place the film in the camera and wiggle it a little.
Take out the film and look at the foil. It should have the markings of the contacts.
Now go have fun and shoot!
