Introduction: DIY - IPad Joystick
I love my iPad. I can do just about anything on it. But when it comes to gaming, you just can't beat the precision of physical controls. You can find joysticks on the market, but why spend 25 bucks when you can make something just as good at home? So, after weeks of tinkering and testing, I've got a working model that I made with common household items for less than $5.
I hope you enjoy building it and playing all the joystick controlled apps on your iPad.
Step 1: Gather Materials
You'll need the following items to build your iPad Joystick:
1. A Nerf dart (with a suction cup end)
2. A chess piece (a bishop is the best)
3. A bouncy ball
4. Scotch Brite non-scratch cleaning sponge (most any scratch resistant sponge should work)
5. Aluminum foil (8" x 8")
6. Scissors
7. A hot glue gun
Optional:
1. A single hole punch
3. A bouncy ball
6. Scissors
7. A hot glue gun
Optional:
Step 2: Assemble the Structure
Use the scissors to cut a slice halfway through the bouncy ball. Open the cut and insert the top of the chess piece. Use a hot glue gun to secure it into place.
Step 3: Wrap Your Structure
Cut out a square of tin foil roughly 8" x 8" and wrap it snugly around the piece you just assembled. Try to retain as much of the original shape of the piece as possible. Make sure to cover the bottom of the chess piece as well and try to keep it as flat as posible
Use the scissors to cut a small hole in the base, roughly the width of a pencil.
Step 4: Prepare the Sponge
Use the scissors to cut the sponge into a 1.25" diameter circle. Slice it so it is only 1/8 - 3/16" thick.
Use the single hole punch (if available) or scissors to cut a hole through the center of the circular sponge.
Line up the hole in the sponge with the hole in the bottom of the foil-covered piece, then use the hot glue gun to glue the sponge in place. Do not use too much glue because the sponge still needs to have contact with the foil for the joystick to work.
Step 5: Attach the Suction Cup
Disassemble the Nerf dart, removing the foam part of the dart. Next, cut away the plastic sides that surrounded the foam.
Insert the plastic shaft of the dart through the hole in the sponge and into the hole in the bottom of the chess piece. Use the hot glue gun to glue it into place.
Step 6: Have Fun
And you're done! Now sit back, relax, and enjoy the many joystick controled apps for the iPad and Android tablets.
My favoritve joystick compatible apps are:
1. PAC-MAN
2. Edge
3. Death Worm
4. Radiant HD
5. NOVA
6. Reckless Racing
7. Death Rally
8. Meteor Blitz
9. MX Mayhem
10. Star Blitz
11. Buganoids HD
12. Revolt
13. Gun Bros.
14. Galaga 30th Collection
Feel free to share your favorite games in the comments below.
1. PAC-MAN
2. Edge
3. Death Worm
4. Radiant HD
5. NOVA
6. Reckless Racing
7. Death Rally
8. Meteor Blitz
9. MX Mayhem
10. Star Blitz
11. Buganoids HD
12. Revolt
13. Gun Bros.
