Introduction: DIY Jean Purse
For this tutorial I will be making a purse from a pair of old jeans. This project could also work with a jean skirt. First we need to get together all our materials.
Step 1:
First you will need a pair of old pants, shorts, or even a jean skirt. I will be using jeans. You will also need:
1-needle and thread
2-seem binder
3-scissors
4-tape measure
5-pins
6-marker
1-needle and thread
2-seem binder
3-scissors
4-tape measure
5-pins
6-marker
Step 2:
Lay your jeans out flat and measure how deep you would like your purse to be. Add an inch or so for the seem.
Step 3:
using your marker, draw a dotted line across desired length.
Step 4:
cut along the dotted line.
Step 5:
turn your skirt inside out.
Step 6:
Sew the bottom of the skirt together, and yes I am sewing all of this by hand because unfortunately I don't own a sewing machine.
Step 7:
Then sew seembinder on top of stitching. Use pins to help hold down the seembinder so that it doesn't get in your way while sewing.
Step 8:
Turn your purse backside right. Ok we finished the base, onto the straps.
Step 9:
take that extra length you cut off earlier and lay it out flat.
Step 10:
cut along the seem. Then cut into 4 equal strips.
Step 11:
With the light side facing out sew 1 end of the straps together
Step 12:
Then fold the strap dark side facing out and sew it all together. We finished our first strap. Repeat steps 12 and 13 for the other strap.
Step 13:
Ok now that we are all finished with the straps we are going to sew them onto the base.
Step 14:
sew one end of the strap right above the front pocket. Sew the other end above the other front pocket. Flip your purse to the back and repeat.
Step 15:
Decorate! Now that we finished the purse we can decorate it! For this tutorial I will be adding rhinestones.
Step 16:
materials you need to rhinestone.
1-hot glue gun
2-rhinestones in various sizes
3-newspaper
I'm also decorating mine with a feather accessory.
1-hot glue gun
3-newspaper
Step 17:
Set out newspaper so you don't get glue on your table.
Step 18: DIY Jean Purse
plan out where you want the rhinestones to go
Step 19:
put a dot of glue where the rhinestone will be placed
Step 20:
press and hold rhinestone in place until secure
Step 21:
After about an hour of hot glue I have finally reached the final product! Voila! Your very own jean purse.Good luck with making yours and thanks for watching..er..umm..reading.
