DIY Jean Purse
Intro: DIY Jean Purse
For this tutorial I will be making a purse from a pair of old jeans. This project could also work with a jean skirt. First we need to get together all our materials.
STEP 1:
First you will need a pair of old pants, shorts, or even a jean skirt. I will be using jeans. You will also need:
1-needle and thread
2-seem binder
3-scissors
4-tape measure
5-pins
6-marker
1-needle and thread
2-seem binder
3-scissors
4-tape measure
5-pins
6-marker
STEP 2:
Lay your jeans out flat and measure how deep you would like your purse to be. Add an inch or so for the seem.
STEP 3:
using your marker, draw a dotted line across desired length.
STEP 4:
cut along the dotted line.
STEP 5:
turn your skirt inside out.
STEP 6:
Sew the bottom of the skirt together, and yes I am sewing all of this by hand because unfortunately I don't own a sewing machine.
STEP 7:
Then sew seembinder on top of stitching. Use pins to help hold down the seembinder so that it doesn't get in your way while sewing.
STEP 8:
Turn your purse backside right. Ok we finished the base, onto the straps.
STEP 9:
take that extra length you cut off earlier and lay it out flat.
STEP 10:
cut along the seem. Then cut into 4 equal strips.
STEP 11:
With the light side facing out sew 1 end of the straps together
STEP 12:
Then fold the strap dark side facing out and sew it all together. We finished our first strap. Repeat steps 12 and 13 for the other strap.
STEP 13:
Ok now that we are all finished with the straps we are going to sew them onto the base.
STEP 14:
sew one end of the strap right above the front pocket. Sew the other end above the other front pocket. Flip your purse to the back and repeat.
STEP 15:
Decorate! Now that we finished the purse we can decorate it! For this tutorial I will be adding rhinestones.
STEP 16:
materials you need to rhinestone.
1-hot glue gun
2-rhinestones in various sizes
3-newspaper
I'm also decorating mine with a feather accessory.
1-hot glue gun
3-newspaper
STEP 17:
Set out newspaper so you don't get glue on your table.
STEP 18: DIY Jean Purse
plan out where you want the rhinestones to go
STEP 19:
put a dot of glue where the rhinestone will be placed
STEP 20:
press and hold rhinestone in place until secure
STEP 21:
After about an hour of hot glue I have finally reached the final product! Voila! Your very own jean purse.Good luck with making yours and thanks for watching..er..umm..reading.
3 Comments
deecatt45 4 years ago
Penolopy Bulnick 11 years ago
nnylyak_717 11 years ago
