DIY Kitchen Shelving Unit Under $150
Intro: DIY Kitchen Shelving Unit Under $150
This is my second DIY project, I built this shelving unit from scratch using spruce pine from home improvement store.
Spruce pine lumbers
2"x4" by 12FT x 4
2"x3" by 8FT x 3
1"x6" by 12FT x 4
1"x8" by 12FT x 2
1"x12" by 6FT x 1
Tools:
Table saw, drill/driver, jigsaw, clamps
STEP 1: Attaching Four Legs Together to Complete the First Frame
- Simply combine 2x4 and 2x3 together for all four legs, length is 3 ft
- Frame is 5'6" x 14" for the top and bottom using 2x4 lumber
- Frame for the middle should be the same dimension, but use 2x3 instead.
- Make sure to secure the screw from the inside of the frame and on the side.
STEP 2: Joining All Three Pieces to Make the Table Top
You will need to do this for the middle shelf as well but with 2x3 frame.
STEP 3: Attaching the Mid and Bottom Frame
You will need to cut four pieces of 2x3 with length of 8 inches.
STEP 4: Adding More Boards on the Bottom Shelf
STEP 5: Adding 2"x3" Poles to All for Corners to Secure the Middle Shelf
To make it easy to adjust the height of the middle shelf, I only use 4 pieces of 2x3 to secure the middle shelf without having to use screws or nails.
3 Comments
KatrinaC41 6 years ago
seamster 9 years ago
Very nicely done, thanks for sharing this!
This turned out excellent, and looks like a great project for newer woodworkers. Can't wait to see what you make next!
makeitgr8t 9 years ago
Thanks, I am pretty happy to see the final product... I guess watching all the DIY TV shows and surfing the web can come in handy. :-)
