Introduction: DIY Marimo Ball Habitat Tank!
whoever has marimo probably knows that they come from dark, cold rivers that are constantly moving them.
i wanted to recreate that habitat for my marimo to keep them as healthy as possible.
here is a VERY easy way to make the tank.
ITEMS for need:
All Living Things Critter tote in size small, it looks like a cricket keeper.
waterfall moter, I took apart my broke desktop fishtank from thinkgeek and used that.
5 volt cord, if you are using the desktop aquarium moter, change for a different moter.
big pebbles
marimo
TOOLS:
dremel
hot glue
ITEMS for need:
big pebbles
marimo
TOOLS:
dremel
hot glue
Step 1: Dremel a Hole in the Critter Keeper.
dremel the hole just big enough to put the wire through.
(have an adult do this)
Step 2: Hot Glue the Hole With the Cord
make sure you glue it good. on both the inside and outside.
Step 3: Check for Leaks
check the container for leaks for by putting water in it a couple of times.
Step 4: Add Pebbles , Water and Marimo
add the pebbles,water and marimo.
Step 5: Watch It Go!
(I had to separate the video into ten second, movie maker was not working)
